 Lazy Jack System for C-250?
MartinJW
Initially Posted - 04/11/2008 :  01:44:33  Show Profile
Hi again folks,
I'm looking for a Lazy Jack system. My Catalina dealer told me I could simply set up some lines for this, but I'm leaning towards something more sophisticated.
West Marine has a Harken set-up for about $200 even. They also sell a Schaefer system for $290.
Any thoughts, suggestions, recommendations?
Thanks!
C25/250 Int'l Ass'n Member
2008 C-250 WK #973
"Bluebell"
Lake Tahoe, CA/NV
Response Posted - 04/11/2008 :  09:00:42  Show Profile
Check out [url="http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=17161&SearchTerms=Lazy,jack"]Frank Farmer's set up[/url] Lazy jacks aren't very sophisticated, they just work well. Frank probably set his up for less than $50.
Response Posted - 04/11/2008 :  11:07:48  Show Profile
Search the archive for $5 lazy jacks from 3/06. I have since used the minature blocks at the mast and common point. Very satisfied with the results. The blocks are availabe at apsltd.com (it's now $20 lazy jacks )
zebra50
Response Posted - 04/11/2008 :  13:25:49  Show Profile
I used the Harkin system, found it easy to install and it works great
Response Posted - 04/11/2008 :  19:41:14  Show Profile  Visit britinusa's Homepage
When you price out the 3/16" line involved, $200 is not as bad as you think.
MartinJW
Response Posted - 04/20/2008 :  14:53:16  Show Profile
Has anyone tried a Jiffy Jax system? Have a look:
http://www.jiffyjax.com/index.html
I'm thinking about giving this a try.
Any thoughts, opinions, suggestions?
Martin
Turk
Response Posted - 04/21/2008 :  09:30:34  Show Profile  Visit Turk's Homepage
This is the system I used - from sailcare. It uses rope and bungie cord. It's great! Stretches to deploy, then retracts to the mast. Simple design and very easy to install (a few rivets). The kit they give you has everything you need including rivets, drill bit, cord,rope, stainless parts and the instructions are great. Replacement shock cord for the entire thing is $15 but the cord should last for many years.
A little planning is needed to make sure it fully retracts and still has tension on the cord so it remains tight to the mast. Here is the link:
http://www.sailcare.com/sailcradle.shtml
MartinJW
Response Posted - 04/21/2008 :  19:56:34  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Turk</i>
<br />This is the system I used - from sailcare. It uses rope and bungie cord. It's great! Stretches to deploy, then retracts to the mast. Simple design and very easy to install (a few rivets). The kit they give you has everything you need including rivets, drill bit, cord,rope, stainless parts and the instructions are great. Replacement shock cord for the entire thing is $15 but the cord should last for many years.
Does this deploy quickly and easily?
Do you need to go forward to the mast to deploy it?
The Sailcare.com pictures aren't very good; it looks like you would need to clip all the hooks onto the boom each time you want to use it, which seems like it would be slow and possibly dangerous.
Martin
Turk
Response Posted - 04/21/2008 :  22:44:45  Show Profile  Visit Turk's Homepage
[/quote]Does this deploy quickly and easily?
Martin
[/quote]
Yes, you need to go forward to grab 2 hooks. Pull them to the back of the boom, then pull down the middle to a hook on each side of the boom. Dangerous? Hardly. Very simple with nothing to adjust. Head up wind to deploy. The boat has stopped.
My auto pilot makes it even easier.
If you want to do this in a hurricane, it might be dangerous to go up front, I would be hauling the main down into the cabin at that point.
Edited by - Turk on 04/21/2008 22:45:32
AADIVER
Response Posted - 04/21/2008 :  23:13:55  Show Profile  Visit AADIVER's Homepage
Why don't you "yauhties" save your hard earned dough and install my el cheapo but simple and effective jacks:
http://im1.shutterfly.com/procserv/47b7d801b3127cce867e436366e600000036102KcuHLVmxo
Edited by - AADIVER on 04/21/2008 23:15:36
johnsonp
Response Posted - 04/22/2008 :  13:47:03  Show Profile
<font color="blue"><font size="4"><font face="Comic Sans MS">MartinJW
I used these Sailcare jacks for years on my C250.
The lower lines are bungee cord and never had a problem. Since I'm a senior, sailed single alot, the Sailcare was very quick and easy to use.
You can drop either side very easy and raise the main and not worry about the sail head getting caught.
Sailing at Tahoe the winds would shift a lot especially around Emerald bay inlet area and always had to raise and lower sail to get in and out.
If you are a do it yourself person, Frank's system will give you a start.
paulj</font id="Comic Sans MS"></font id="size4"></font id="blue">
MartinJW
Response Posted - 04/23/2008 :  20:56:45  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by johnsonp</i>
<br /><font color="blue"><font size="4"><font face="Comic Sans MS">MartinJW
Thanks, Paul.
Martin
MartinJW
Response Posted - 04/23/2008 :  20:57:41  Show Profile
<br /><hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Does this deploy quickly and easily?
Martin
[/quote]
[/quote]
Thanks, Turk,
Martin
