 Stove Gimbal Mount
skrenz
Initially Posted - 04/17/2008 :  19:25:43  Show Profile
Can anyone supply a close up picture of the gimbal mount for the original equipment alcohol stove? I need to fabricate one. Thanks in advance.
Steve Krenz
`Elan
1978 SR/SK #482
Santa Fe, New Mexico
Response Posted - 04/18/2008 :  19:40:34  Show Profile
Steve,
I'm going to the boat tomorrow I'll try and remember to take some pictures for you.
Happy D
Response Posted - 04/21/2008 :  09:28:32  Show Profile
Steve,
Exactly what do you need dimensions and a photo of?
Do you need the mounts that screw to the side of the stove, with the counter weight, or just the trunions that are screwed to the side of the heat shield?
Dan
Edited by - Happy D on 04/21/2008 09:38:12
skrenz
Response Posted - 04/22/2008 :  00:11:13  Show Profile
I guess I need both. HappyD, your picture is very helpful. I assume that this is the trunions for the pivot and is attached to the heat shield. I'm looking for pictures of both the trunions and the mounts.
Happy D
Response Posted - 04/22/2008 :  08:01:58  Show Profile
Here are more photos. I'll get detailed dimensions if you need them. It'll take a few days though. I have to head out of town.
(Have to go to Jacksonville)
Dan
The counter weight is a 1 1/4" galvanized bar, 18" long.
skrenz
Response Posted - 04/24/2008 :  17:17:29  Show Profile
What a great response. Thanks HappyD for the effort you put into this. I'm now wondering if I can find these parts any where. I guess I'll post on the shop meet. Thanks again.
Happy D
Response Posted - 04/25/2008 :  06:22:24  Show Profile
It doesn't look easy or in-expensive to build. I have to believe buying and older stove that doesn't work might be better.
Instead of bending it, you could weld all the corners, or build it flat. Can you weld stainless?
The heat shield on mine is tapered. It is wider in the front than it is in the back.
Edited by - Happy D on 04/25/2008 06:25:14
