 water tank - removal?
JimB517
Initially Posted - 05/10/2008 :  11:30:05  Show Profile  Visit JimB517's Homepage
Any one removed their water tank without destroying the tank or the port setee?
In 4 years now I have never used water from the tank. I recently pumped it dry. I would much rather have the storage area.
I am contemplating simply cutting the top off the tank and using it to store bottled water, beer, and other items, or cutting that fiberglass batten across the top of the port setee and trying to lift the tank out.
I save up gallon cranberry juice jugs (very stout plastic) and use them to carry water on my voyages.
Ideas?
Indiscipline 1978 FK SR #398
stampeder
Response Posted - 05/10/2008 :  11:31:52  Show Profile
do you have a traditional interior?
Happy D
Response Posted - 05/10/2008 :  13:00:14  Show Profile
I pulled mine out. If you cut the plywood at the ends of the tank, it comes out the aft opening of the stbd settee without cutting the fiberglass or the tank.
Kendall
Response Posted - 05/10/2008 :  15:20:52  Show Profile
Ours also has been out. It takes a little bit of effort to remove the pylwood though. Personally I think the tank should be in a more convenient place to be easily removable, like the quarter berth.
frog0911
Response Posted - 05/10/2008 :  16:01:23  Show Profile
If storage is the function, IMHO your idea to cut out the top is the perfect one. It is a pain cutting out the plywood end spacers and then reinstalling them. They are required to support the seat. If you cut the top you could even use it to for cold storage and as the ice melts use the water sink pump to empty while washing dishes etc. True the ice would not last more than a couple of days, but a cold towel around the neck on hot sailing days is very refreshing.
quilombo
Response Posted - 05/10/2008 :  16:17:56  Show Profile
you guys dont use water??? strange
ddlyle
Response Posted - 05/10/2008 :  17:12:04  Show Profile  Visit ddlyle's Homepage
The water stored in these things usually isn't potable because of bacteria, taste etc.
Some use the onboard water for washing.
Response Posted - 05/10/2008 :  21:36:08  Show Profile  Visit Frank Hopper's Homepage
I had to cut out a glassed in bulkhead where mine was located, aft under the starboard settee.
skrenz
Response Posted - 05/10/2008 :  21:53:52  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ddlyle</i>
<br />The water stored in these things usually isn't potable because of bacteria, taste etc.
Bacteria: bleach
Taste: rinse out after the bleach really well and then use a little red wine in the water.
I might not want to mix my PM libation with this water but it certainly can be made safe enough to cook with.
tinob
Response Posted - 05/11/2008 :  09:15:29  Show Profile
I have an'83 dinette model and removed the tank to clean it. Removing it was simple, no cutting required. The seat cover was held in place with a few s.s. screws and the tank was held in place with several dense foam pre-shaped blocks. When the seat top is screwed back down it secures the tank.
Val on the hard DAGNABIT # 3936, Patchogue,N.Y.
Response Posted - 05/11/2008 :  18:53:17  Show Profile
I used bleach, and plenty of it, to clean out the tank and hoses. Afterwards, I used white vinegar (a gallon bottle) plus a gallon of water, then had the Admiral and I stood on either side of the boat trying to see who could get their rail into the water first.
Shaking the boat up also shook the vinegar in the tank. We still don't drink the water, as we carry bottled water like Jim B, but water quality for washing has certainly improved measureably!
My problem is NOT the water in the tank - it's the water going down the drain! It is SLO-O-O-O-OW as heck! Is there any way I can remove the drains and drain hoses to clean them out without flooding the boat out????
I figure if I pull the hose, the Atlantic Ocean will rush in to sink old <i>Passage</i>.
Response Posted - 05/11/2008 :  19:07:18  Show Profile
I would be inclined to close the seacock
