 Shelving Mod
Initially Posted - 06/04/2008 :  22:53:40  Show Profile
I've been wanting to do this mod and finally got around to it. We do not use the space under the galley for a cooler so I wanted to make storage shelves. I used angle (1") aluminum for the mounts and 3/4" "Starboard" for the shelves. 1/4" SS bolts are used to mount the brackets and #10 SS screws hold the shelves to the brackets.
We plan to use plastic baskets to store things in and then add a bungee to the front of each shelf to stop the baskets from sliding out.
The shelves:
SS bolts on the aft berth side:
SS bolts under the galley:
When we go for cruises we find we need more space so this mod should help. I got the shelves from the same Internet custom cutting board shop that I used to make the cockpit table and helmsman seat. They round the edges and make any size you want.
Edited by - Nautiduck on 06/04/2008 23:06:07
MartinJW
Response Posted - 06/05/2008 :  09:36:41  Show Profile
This is nice-looking work, Randy. I have a couple of questions for you.
Where do you keep your cooler on the boat? (Do you not use a cooler on your boat?)
Who/what is the internet custom cutting board shop you used?
Thanks!
Martin
Edited by - MartinJW on 06/05/2008 09:41:15
Response Posted - 06/05/2008 :  10:17:32  Show Profile
For cruising we use a large "5 day" Igloo cooler that is kept under the cabin table. For day use we have a small cooler that goes behind the cabin steps.
The shelves came from:
[url="http://www.cuttingboardcompany.com/"]Custom cutting boards[/url]
Response Posted - 06/05/2008 :  10:47:00  Show Profile
Very cool, Randy. Have you thought about fiddles instead of the bungees? I think they'd look better.
Response Posted - 06/05/2008 :  12:56:16  Show Profile
Fiddles would like nice, I agree. I wonder if there is some sort of folding/locking hinge that would allow a fiddle to be up most of the time but down when needed? Also, would the fiddles be teak or the black lexan to match the galley fiddles??
Response Posted - 06/05/2008 :  13:08:21  Show Profile
Teak would be my choice. Our boats could use more of it.
Maybe attached with a piano hinge and a simple latch?
MartinJW
Response Posted - 06/05/2008 :  15:56:10  Show Profile
<br />For cruising we use a large "5 day" Igloo cooler that is kept under the cabin table. ...[edited]
Do you know the size or Igloo model that you're using? Does this fit especially well under the table?
We've been shopping for a cooler to fit under the galley, but we're not very happy with this arrangement. A cooler that fits under the table, forward in the cabin, sounds like a good idea.
Martin
frog0911
Response Posted - 06/05/2008 :  17:47:55  Show Profile
The 50 quart IGLOO will fit nicely in the storage area, handles down, or under the table. WM usually has some big sale on these this time of the year. (FATHER'S DAY)
Do like your mod though Randy. Will show it to the Boss and who knows.
Edited by - frog0911 on 06/05/2008 17:49:37
MartinJW
Response Posted - 06/05/2008 :  21:25:28  Show Profile
According to www.Igloo-Store.com, there are a number of 50-ish quart Igloo coolers that might fit:
Igloo Maxcold 50: 25.50"L x 15.25"W x 17.38"H
Igloo Marine 48: 25.38"L x 14.75"W x 14.75"H
Igloo Marine 54: 25.50"L x 15.50"W x 15.50"H
It looks like Academy Sports & Outdoors (sporting goods store chain in the South?) has the [url="http://www.academy.com/index.php?page=content&target=products/outdoors/camping/maxcold_coolers&start=0&selectedSKU=0222-01260-3018"]Maxcold 50 for only $27.99[/url], which is much lower than any online price I could find. West Marine has the Marine 48 & 54 quart coolers for about $50.
Edited by - MartinJW on 06/05/2008 21:43:07
Response Posted - 06/05/2008 :  22:45:10  Show Profile
Ours is the 54 or bigger, I can't find a model on it. Our experience is that the bigger units will "fit" in the spot under the counter but it is awkward to actually use them there due to the lack of height lifting the top and then lifting the whole unit out of there full of ice, etc. Our large Iglooo just slides anywhere you want it under the table. It can be secured to the mast post but we never found that necessary. For us, the need for more storage when cruising is more important. Except for cruising, we use a small easy-to-carry cooler for a few sandwiches and drinks.
Response Posted - 06/05/2008 :  23:19:36  Show Profile  Visit delliottg's Homepage
We also use a five day cooler which fits in between the table & the settee. We actually have two of them, the first one was too big & didn't fit well so we bought the second. Neither were horribly expensive. We use the blue not-cooler as storage for plates & cook ware, I'm actually not sure what all Rita's got in there, she sort of claimed it for her own. I do like the idea of the shelves, but I'm done doing projects for this "winter". I've got one more thing to rig, and that's the power tiller setup for our new engine. I'm hoping for no rain over the weekend to get it set up.
frog0911
Response Posted - 06/06/2008 :  16:03:36  Show Profile
The one I have is called the "Ultra Cold 50" which probably is what they call the Max Cold now. The dimensions are the same. When we go on a long cruise we also take the 94 Quart Igloo which we store under the table starboard.
Response Posted - 07/04/2008 :  22:09:14  Show Profile
The shelving mod is now completed with the addition of some nice woven wood containers and bungee closures. We got the containers from [url="http://www.containerstore.com/browse/Product.jhtml?CATID=71225&PRODID=10018111"]The Container Store[/url] and the set of two baskets fits great in the shelf, basically filling the whole shelf area. I sprayed the baskets with three coats of Helmsman varnish.
Then I added small folding padeyes and bungee to keep the containers from slipping out while heeling. Overall adds 4 square feet of storage for food and galley items.
The bungee and neat little hooks (you put them on yourself) are from West Marine.
This mod takes wasted space and makes it useful. The Admiral likes the extra storage and the fact that the woven containers add some natural elements to the cabin.
Edited by - Nautiduck on 07/04/2008 22:16:26
