 Sail number falling off
mrapkins
Initially Posted - 06/10/2008 :  10:39:41  Show Profile
The sail number is falling off my main. Can anyone recommend an adhesive to re-attach it?
skrenz
Response Posted - 06/10/2008 :  10:52:23  Show Profile
I would ask the folks at Sailrite (sailrite@sailrite.com). They sell a number of adhesives that would probably do the job. More importantly, they are very helpful and knowledgeable about all fabric questions.
Response Posted - 06/10/2008 :  14:23:05  Show Profile  Visit Champipple's Homepage
Go to sailrite or call your local loft (IF YOU Have one...(frank that part was for you)) they will get you a new one for a few bucks. They aren't required unless you race the boat, so your other option is just to let it go.
JimB517
Response Posted - 06/10/2008 :  15:10:22  Show Profile  Visit JimB517's Homepage
Sailrite sells the numbers on the web for $0.50 each. Peel off the backing, stick on, it will never come off.
At Ease
Response Posted - 06/12/2008 :  17:30:08  Show Profile
Any spray adhesive should work. I've had good luck with 3M....got it at Lowes.
Response Posted - 06/12/2008 :  18:22:44  Show Profile  Visit piseas's Homepage
My registration numbers come off my dinghy. I will try the spray. Lowes down the street from me. Tks.
Stardog
Response Posted - 06/26/2008 :  20:26:32  Show Profile
I worked as a sailmaker for a few years and found out that when the numbers are coming off it's likely there are other things that need attention. I would recommend you go to your local sailmaker and have them check out your sail. If the cloth is holding up and stitching is getting weak, you can have the stitching resewn and be back in business for not much money. I recommend having them put new numbers on for you also, it takes a lot of practice to learn how to get those numbers on straight. Even in a sailloft I've seen a fair number of logos and numbers ruined when they were being installed.
