 Manual Bilge Pump
Initially Posted - 06/13/2008 :  12:01:48  Show Profile
Was curious if I am the only one with this issue. I have been looking to replace the manual bilge pump on my 1980 25. It looks like a typical Whale/Rule pump, however, the one sold by CD has the handle centered witihin the four monthing holes while my boat has an offset pump handle and a @1"x5" opening with snap in cover where the handle goes/moves. Does anyone know exactly what model of what brand pump Catalina used in 1980?
Peter Bigelow
Rowayton, Ct
Response Posted - 06/13/2008 :  15:13:11  Show Profile  Visit piseas's Homepage
Peter, You may do what I am doing, installing an electric bilge pump.
Under $100.
quilombo
Response Posted - 06/13/2008 :  16:13:40  Show Profile
I agree with the electric, unless you dont have any battery power, I would def go with an electric,
and make sure if you do use an electric, have it direct wired to a battery regardless of what your battery switch is on
so that if you accidentally shut off all battery power , your bilge pump will still work,
and its nice to have a manual on switch to
Edited by - quilombo on 06/13/2008 16:14:13
Response Posted - 06/13/2008 :  17:14:45  Show Profile  Visit piseas's Homepage
Oops, didnt know Peter didnt have battery. Anyway, that pump may no longer be available. I am sure Catalina can advise you or know of a replacement. Also batteries are pretty inexpensive.
Response Posted - 06/14/2008 :  21:46:09  Show Profile
Thanks for the input. I do have batteries but want a manual the security of a manual pump -- just do not want to cut additional holes to accomodate what should be available somewhere.
