This is a two man job since you will be torqueing the screws topside with a screw gun/drill and someone else is holding the nut. I did this project last year and I highly recommend 4200 for bedding. No leaks all season!
Be sure to put a bead around each screw and the stanchion plate to ensure a proper seal. Don't use too much or you will have 4200 all over the place. Be sure to have rags available to wipe excess away.
I did a section of the genoa track last year, without removing it. Some might say this isn't a good idea, but I wasn't prepared to take the whole thing off at the time. I removed the teak trim in the cabin that covers the nuts holding the track bolts. Then, with a friend in the cabin, I removed the bolts that in the area where I had some winter seepage (about a 5' section). I shot some silicone down the holes and ran the bolts back in. It got a little messy for my friend, but he's a sailer... <img src=icon_smile_wink.gif border=0 align=middle>
You might have more luck with a wrench on the nuts below to break these bolts loose--especially if the problem is corrosion between the aluminum track and the stainless bolt--that's likely. You may have to chip a little fiber insulation around the nuts to get a wrench on them.
On the stanchions, I've been warned not to bed the entire base--just around the bolts. You don't want to seal in water that may enter the top of the stanchion. I suggest tightening them from below--just finger tight--then allowing the 4200 or Life Caulk (essentially the same thing) to cure. Then crank down the nuts from below to form a tight gasket. If you turn the bolts from above after the stuff cures, it will tend to break the seal around them.
Good luck--I'm lining up my "on the hard" projects, too!
