 Electronics Help
brrit
Initially Posted - 08/21/2008 :  14:07:42  Show Profile  Visit brrit's Homepage
Warning: This post will include numerous "newbie" descriptions of electronic equipment.
My electronic wind gauge is sitting about 20-25 degrees off center at the top of the mast. A couple of weeks ago I went up the mast and realigned it, but within minutes it quickly returned to its original incorrect position. There didn't appear to be any screws or things to adjust on the unit so I thought all was well.
So... I'm back where I started. Is there any way to make the unit work with this sitting 20-25 degree off up the mast?
I've been fighting with this for a few months now and am quite frustrated with it. Any ideas? Is it time to just give up on it?
Thanks!
Bryan
Bryan Ritchie
"Serenity Now"
1989 C-25 TR/FK #5829
Dallas, Texas
www.athomewithdad.net
Response Posted - 08/21/2008 :  16:53:11  Show Profile
If you supply the make and model of the wind instrument you might get a response.
The condition you describe is obviously not normal, and there either has to be a way of adjusting it, or something has to be broken. If nobody here can provide you the specific information you need, I suggest you take the mast down and examine the unit more closely. Perhaps you can find the solution. If you were able to adjust it, but it failed to stay in place, maybe the addition of a lock washer or locking bolt will help keep it in place after you adjust it.
SCnewbie
Response Posted - 08/21/2008 :  20:20:06  Show Profile
Need the model info however if you look in the manual, you may find a parameter you can change to set a "position offset" value to compensate for it being off center.
Response Posted - 08/22/2008 :  07:28:06  Show Profile  Visit britinusa's Homepage
Our Raymarine wind transducer (vane with a wobble) almost fell off once. The nut securing the support tube at the top of the mast became loose while we were on the water and the guage was only held in place by the tension of the electrical wire. It still worked just fine. If the wind were very light, then the angle would probably not cause too great a significant error (the wobble weight would accelerate downhill but slow up hill).
However the wind angle would certainly be off if the transducer was rotated. If it is twisted but rigid, then you can just calibrate it for the correct angle.
Can you take a pic of the attachment point as well as provide the model info.
Edited by - britinusa on 08/22/2008 07:29:56
brrit
Response Posted - 08/22/2008 :  07:36:51  Show Profile  Visit brrit's Homepage
The unit is a Autohelm ST50 Plus.
mrapkins
Response Posted - 08/22/2008 :  10:24:57  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by brrit</i>
<br />Warning: This post will include numerous "newbie" descriptions of electronic equipment.
Thanks!
Bryan
My Marina told me that the mast on a Catalina 25 was only climable by someone weighing less than 100lbs. Did you ascend in a Bosun's chair, and, if it's not an indelicate question, how much do you weigh?
Response Posted - 08/22/2008 :  10:34:39  Show Profile
I have had people weighing 200lbs up my mast twice. We used a canvas ladder that is hoisted up the kerf.
Response Posted - 08/22/2008 :  14:11:37  Show Profile  Visit aeckhart's Homepage
I've been up once under way in my bosuns chair to change the steaming light bulb. I'm 202 lbs.
Response Posted - 08/22/2008 :  15:18:26  Show Profile
Bryan,
See if this link is any help.
www.raymarine.co.uk/EasySiteWeb/GatewayLink.aspx?alId=1376
Edited by - GaryB on 08/22/2008 15:19:18
