 Measuring a headsail
Initially Posted - 10/31/2008 :  13:24:32  Show Profile
Rather than continue the hijack of a swaap meet thread......
This is copied directly from the [url="http://www.rollytasker.co.uk/order.htm"]Rolly Tasker website[/url] section on sail measurement.
LP explained
A great deal of confusion exists as to the meaning of the percentage number of a Genoa or smaller headsail. For instance a sail may be described as a 150% Genoa. Your headsail size is defined by another dimension called the LP (luff perpendicular). <b>Luff perpendicular is measured as the distance from the clew to the luff at an angle of 90 deg. to the luff. </b> This distance divided by "J" * 100 is the percentage size. A Catalina 27 with a standard rig has a J measurement of 11.25 ft. A 150% genoa for this boat would have a LP measurement of 11.25 * 150/100 = 16.875 ft. A 100% sail would have an LP of 11.25 feet.
1999 C250 SR/WK #410
Bay Village, Ohio
Sailing Lake Erie
Don't Postpone Joy!
Response Posted - 10/31/2008 :  22:17:51  Show Profile
Note that "J" is the length from the base of the forestay to the base of the mast <i>at the level of the deck</i>, as if there was no cabin trunk.
Another aspect of sail measurement is the height of the clew. A "deck sweeper" (racing sail) and a cruising sail with a higher clew for visibility, with the same foot lengths, will have slightly different LPs. A large cruising genoa cut as 150% LP, and racing sails cut as 155, will have a clew about the same distance aft on the boat. Similarly, 130 versus 135 is likely to be a function of the height of the clew. (I had a 130--a slightly higher cruising clew.)
Edited by - Dave Bristle on 10/31/2008 22:20:41
