 Re upholstery
Kmanley
Initially Posted - 11/07/2008 :  09:50:06  Show Profile
I need to update the upholstery any ideas where to start, I am a newbie just bought the boat in September sailed it twice before I had to pull it out of the lake. I have a 1977 Cat 25.
Thank you.
JimB517
Response Posted - 11/07/2008 :  11:12:37  Show Profile  Visit JimB517's Homepage
You can buy new cushions for about $2000 from the factory. That's a lot on a $5000 boat. I cut my old ones apart, the foam was good. Then I sewed new covers using denim as the material. I saved the old vinyl bottoms. I could do one cushion per night so it took me about 2 weeks to do them all. Cost about $200. Sewing is easy.
It would be really easy just to sew bags and then stuff the old cushions inside the bags. Then sew up the bags. This is what I did with marine vinyl for my cockpit cushions. I say "bags" but they are really shaped exactly like the cushions just a little larger.
Easy, easy work on a sewing machine, although I sewed all my interior cushions by hand. I did the cockpit ones on a machine.
Response Posted - 11/07/2008 :  12:00:00  Show Profile
Welcome to the forum.
For 90% discounts on fabric, try your local Golden Colorado Goodwill Thrift Shop or Salvation Army.
I found a set of heavy, full-length drapes for under $20 made of beautiful navy polyester-cotton. If you open all the seams and pleats, you have lots of cloth to cover the cabin cushions with a set of drapes. My V-berth and quarterberth cushions are covered with medium blue velvet, same price.
All sailors know how to sew, don't they? Torn sails? Buccaneer clothing made of mismatched silk?
Happy sailing.
Response Posted - 11/07/2008 :  15:33:44  Show Profile
Welcome, Ken! There are lots of solutions with costs ranging up to about $2K (20 Boat Units). I made a sketch of all of the cushions with dimensions, and took it to a few car/boat upholstery shops. Basically, their quotes were based on the number of cushions--size mattered little or not at all. Our foam smelled of mildew, so we went with new medium-density foam, 1" thicker than original for all but the seat backs. We chose a linen-like upholstery fabric by Sunbrella--not their canvas--and the upholsterer added a 1" fiber mat on top of the foam for some additional softness. The bottoms are vinyl. The whole job came in a little under $2K for 12 cushions (dinette interior).
It made Passage a whole new boat for my Admiral--money well spent. I also suspect it made an impact on my buyer's Admiral--they went below, stayed a few minutes, came back up into the cockpit, and wrote me a check--about 36 hours after I listed her in the Swap Meet.
Kmanley
Response Posted - 11/07/2008 :  17:16:21  Show Profile
Thank you so much that was great information. I won't need to change out the foam just the fabric.
Happy sailing!
KM
Kmanley
Response Posted - 11/10/2008 :  19:50:55  Show Profile
I have to tow my Cat 25 over the continental divide Colorado, can a Ford F150 V8 handle the weight?
Response Posted - 11/11/2008 :  09:08:19  Show Profile
"I have to tow my Cat 25 over the continental divide Colorado, can a Ford F150 V8 handle the weight?"
Ken, best to start a new thead rather than tack-on to an unrelated topic.
That said, does your truck have a 'towing package'? (lower ratio rear end, transmisson cooler etc)
What is the trucks tow rating?
When are you planning to do this crossing.
Personally I'd probably detour north or south to do the crossing rather than plow over the steepest part.
Response Posted - 11/11/2008 :  11:11:43  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Kmanley</i>
<br />I have to tow my Cat 25 over the continental divide Colorado, can a Ford F150 V8 handle the weight?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Over Vail Pass on I-70? Not if there's a flake of snow.
Jefffriday
Response Posted - 11/11/2008 :  16:57:13  Show Profile
Ken, I live on the western slope, just outside of Aspen. I have a GMC 2500 4X4 with the 6L engine. At altitude, I could use more grunt. It's really all about torque (and of course rated towing capacity) up here. I climb the passes at about 40 mph, I could go faster, but I would really have to wind it up to do it. Be sure to check out your brakes, going down a 6% grade is no problem till you need to do a panic stop. Without good trailer brakes, forget about it, you are toast. Where are you headed to and from?
Kmanley
Response Posted - 11/11/2008 :  17:04:25  Show Profile
Frisco to Denver, without trailer brakes, am I crazy to try this?
The guy who I bought the boat from, pulled it from Santa Fe NM to Frisco last year same tralier.
Thanks for your help!
KM
Response Posted - 11/11/2008 :  19:48:17  Show Profile
Ken: You're likely to miss a lot of wisdom on this in an "upholstery" thread... You might want to "Search" on "tow vehicle" and "brakes" and review threads on those subjects, and/or start a new one on the General forum. I will opine that trailer brakes are critical to not risking lives on the highway, and surge brakes with drums are likely to become useless on long downhill runs.
Edited by - Dave Bristle on 11/11/2008 19:54:05
Jefffriday
Response Posted - 11/11/2008 :  20:15:19  Show Profile
Ken: Dave is correct about missing allot by using this thread instead of starting a new one. That said, I had to bring my boat home from Houston to Basalt without functioning brakes. It only made the trip up the frying pan river to the lake after that before getting all new 4 wheel disk brakes on it. If you do it, choose the time and day carefully. You are probably aware of the incredible traffic on Sun afternoons (actually most evenings). I would get the lights working and go in the middle of the night, at speeds less than 40 down the big hills. When I was forced into my adventure, I planned it to come through Houston at about 1:00 am the Dallas at 5:00 am. I hit denver at 10:00 the following day and went through the mountains late. If you are going to need the brakes done anyway, you might see if there is someone is Frisco who can handle it, but I doubt it. If you decide to do your own, I got steered to Champion Trailers through this site and had very good luck getting advice, parts, and support. Feel free to email me if I can be of any help...
Kmanley
Response Posted - 11/11/2008 :  20:46:14  Show Profile
I understand, being new to the site I thought I did start a new thread.
It won't happen again.
Ken
