Back in the summer (ahhhh, summer), I was adopted by a beautiful albeit neglected C25 swing keel. Luckily for us, I enjoy working on boats almost as much as sailing them. I've been busy doing the typical refit/upgrade thing this fall (new lines, thru-hulls, window seals, etc) and replacing the keel cable, maintenance of the winch, and refinishing the companionway was last week's "soup du jour". I had ordered a new keel cable and turning ball from CD and ordered a new keel cable hose as a spare. The ladder came out, the old cable was cut from the keel and then I went to remove the keel cable hose.
It literally broke apart in my hand. Right at the top of the volcano.
I'm not sure how I missed this terribly dry-rotted but absolutely essential barrier between a dry bilge and the Chesapeake Bay when I purchased the boat (probably because she had so many other pimples), but luckily for us, I found it while on the hard. The old turning ball was very badly worn (it looked like it was frozen and the cable had flat spotted one side) and it too was soon replaced.
All you swing keel owners, be aware. Check your keel cable and turning ball, and please check your keel cable hose!
Good point Tom. CD makes a point of selling marine exhaust hose for this purpose, saying the reinforcements in it's design make it the safest choice. They also sell clamps with depressions rather than cuts for the adjusting gear to engage with. They say that prevents abrasion of the rubber by the more conventional hose clamps. ... and as always on every waterline hose, double clamp. My swinger came with a PVC "shield" over the hose as well, seemed like a good idea.
Indeed, one of the sailors at the local club had his keel drop, and it cause damage to the hull. Very expensive repair. 60 - 80 bucks for new cable and hose is money well spent.
Well, I finally figured out how to do the "shutterfly" thing, so I thought I'd post a few pictures of what I discovered when I looked closely at my keel cable thru-hull hose.
This is the forward facing side of the keel cable hose. A little dry-rot, but no biggie, right? Here is the back side... yikes, it literally fell apart in my hands when I tried to remove it. With many boats out of the water this time if the year, now is a great time for all you swingers to check that keel cable and hose! Also, the turning ball was severely flat-sided and needed to be replaced as well. Easy fixes both and great piece of mind!
When is it advisable to replace the bronze tube that holds the turning ball? How do you install the turning ball so it doesn't drop too far into the tube? I assume it has to be lowered somehow into the tube and then lined up with the pin holes in the bronze tube in order to insert the pin on which it rotates. Do you insert the ball after running the new cable?
Okay. In your picture, the pin is much closer to the top of the tube than in the pics on the CD website. also looks to be a very snug fit and relatively easy to inspect with the hose removed. Add to my list of things to do next time she's hauled out, hopefully this spring after the water warms up a bit.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dmpilc</i> <br /> How do you install the turning ball so it doesn't drop too far into the tube? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Spring time, next month or so, I plan on replacing the pivot end of the keel pin - - with the improved brackets so the keel doesn't rock. CD has a kit for it. I think it is well worth the work and expense.
Next year, I replace the cable, ball, and pin.
BTW - I remember dropping the ball in the tube. I think I had to use a small screw driver to poke through the pin hole to get the ball out and start over.
