 Degrees
Initially Posted - 12/19/2008 :  06:00:48  Show Profile  Visit britinusa's Homepage
I really really should know how this works, but as the forum does not allow html code in a post, then I'm stumped.
I have posted this in the Testing forum so that we can use it when needed (Read the testing forum)
Your posts will change direction by approximately 10°
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Edited by - britinusa on 12/19/2008 06:01:14
KD4AO
Response Posted - 12/19/2008 :  06:44:36  Show Profile
Paul, degree (º) is the extended ascii code 167. You type it by holding down the alt key while entering 167. There are lots of sites that can supply the Extended ASCII Codes if you google for it. And see, old retired IBMers are good for something, Ha Ha. Merry Christmas. Bob
Response Posted - 12/19/2008 :  06:51:47  Show Profile  Visit britinusa's Homepage
Thanks Bob! I'll update my msg in the testing forum.
Wow, how long since I tried to enter an ascii code into a none html forum! (or &0186;)!
Have not been up to the blue lake area of Boca in years!
KD4AO
Response Posted - 12/19/2008 :  07:04:06  Show Profile
Paul there is also a Windows Character map in Accessories, System Tools, Character Map, listed by windows font. Kind of complicated to use though.
Response Posted - 12/19/2008 :  07:18:11  Show Profile  Visit DaveR's Homepage
It's odd that you mention this subject because yesterday a friend of mine [url="http://www.mesweet.net/printaltsymbols.html"]emailed me a web page[/url] that posts many ASCII codes.
Edited by - DaveR on 12/19/2008 07:25:00
Response Posted - 12/19/2008 :  08:36:33  Show Profile
Thanks Bob, I learned something new today.
Response Posted - 12/19/2008 :  10:18:40  Show Profile
For Mac people, just hold down the "apple" key and press 0 (zero).
Response Posted - 12/19/2008 :  10:33:10  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DaveR</i>
<br />...a friend of mine [url="http://www.mesweet.net/printaltsymbols.html"]emailed me a web page[/url] that posts many ASCII codes.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Thanks! I bookmarked that--also good for Spanish in e-mails and such... But I haven't discovered how to make it work on my laptop that has the numeric pad on the alpha keys (with NumLock). Any clues? (Bob--it's an IBM--actually a brand new Lenovo... sorta takes me back to my roots when this amount of storage took about 640 desk-sized disk drives! Actually, I go further back than that...)
Edited by - Dave Bristle on 12/19/2008 10:33:58
KD4AO
Response Posted - 12/19/2008 :  11:51:59  Show Profile
Off hand I don't know the answer Dave, but it may be numlock and a combination of FN and ALT. Or something similar.
Old computers talk takes me back to my first computer, a RAMAC 305 which I was trained on in 1959. It had a 5 million character disk drive which was later doubled to 10 million character. The whole computer required about a 30' x 40' room with lots of air conditioning and its power requirement was 240v, 3 phase, 60 amp. It had over 4000 tubes, no transistors.
Ahh the memories. Bob
Response Posted - 12/19/2008 :  12:41:55  Show Profile  Visit delliottg's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Paul, degree (º) is the extended ascii code 167. You type it by holding down the alt key while entering 167<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
The ASCII code is actually ALT+0176, 0167 is §.
Here's a handy chart: http://psacake.com/web/dv.asp
Dave,
I haven't been able to figure out how to enter it on my laptop either, I use Character Map as described earlier if I need special characters, we no longer have a functional desktop at home, so we use our two laptops.
As a point of trivia, a degree symbol is %%d in AutoCAD...
Kendall
Response Posted - 12/19/2008 :  12:54:42  Show Profile
Could you not hit alt and the numbers on the top of the keypad above the letters?
Response Posted - 12/19/2008 :  13:04:13  Show Profile  Visit delliottg's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Could you not hit alt and the numbers on the top of the keypad above the letters?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
You'd think so, but it doesn't work. The numbers on the numerical part of the keyboard aren't wired up in parallel with the ones along the top, so the key sequences for extended characters aren't the same.
Response Posted - 12/19/2008 :  16:11:01  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Kendall</i>
<br />Could you not hit alt and the numbers on the top of the keypad above the letters?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I tried that--no luck.
Bob--I cut my teeth on a 650, 1620, and 7094 at Purdue, then was trained on unit-record equipment in IBM. (Does Ideal Milk Bucket ring a bell?) I have to laugh when I look at this Ideapad keyboard and see "SysRq" and "Break" in the function key row, as if I were hooked up to MVS as a dumb green-screen. And Break is in the corner where eveybody else (but IBM) puts Delete. ...the last gasps of the good-ole OS programmers.
Back to ASCII... there has to be a way!
Edited by - Dave Bristle on 12/19/2008 16:15:06
Response Posted - 12/19/2008 :  16:51:56  Show Profile  Visit britinusa's Homepage
Here's how on my laptop (HP)
There's a fn key (next to left hand crtl key) and a num lk key (next to F12 key)
I put the keyboard in num lk then I can use the Alt and 167 (which for me is alt and jo&) and I get º
Don't forget to take it out of numlock after using it...
Response Posted - 12/19/2008 :  17:05:08  Show Profile
º It works! I could swear I tried doing exactly that before... I have a feeling that in less time than it takes me to remember and do that, I could type "degrees".
Gloss
Response Posted - 12/20/2008 :  17:19:42  Show Profile
I have two BS degrees, so I should be well versed
Response Posted - 12/20/2008 :  17:57:17  Show Profile  Visit britinusa's Homepage
I have been accused of having a degree in BS
Response Posted - 12/20/2008 :  19:36:31  Show Profile  Visit delliottg's Homepage
I don't think you're the only one who's been accused of that here.
