 Grounding Seacocks
Bortiquai
Initially Posted - 12/31/2008 :  10:31:51  Show Profile
I know there are several different theories about grounding in a DC environment.
But what about the seacocks and other thru-hulls? I replaced one seacock about 10 months ago, and it is already showing a little bit of green. A friend said I should just run a wire from the screw on the seacock to the negative bus bar of my DC electrical system.
Is this a good idea? Will it help?
Matt
JimB517
Response Posted - 12/31/2008 :  12:05:49  Show Profile  Visit JimB517's Homepage
No, don't do it. The seacocks and all underwater metal on a bigger boat are wired together but the wire goes to the bonding system (ie a zinc) not to the electrical system. Boat 12 volt system float and do not have a chassis ground. The Catalina 25 does not have a bonding system but you could create one if it was really important to you. With an outboard stored out of the water I don't think you really need it.
Happy D
Response Posted - 12/31/2008 :  13:03:56  Show Profile
If the sea cock is totally isolated from eveything else and only has a rubber hose connected to it, stray current cannot go through it. It is just a piece of bronze sitting in the water. I agree with Jim 100%, don't do it.
Response Posted - 12/31/2008 :  17:05:51  Show Profile
A little green is probably oxidation, galvanic corrosion on bronze usually turns it pinkish. Don't do it is probably the universal position here. Power boats can be different.
Bortiquai
Response Posted - 12/31/2008 :  20:21:53  Show Profile
Awesome. Glad I asked. Thanks to all who chimed in for the advice.
