 Slug topic conclusion:
AADIVER
Initially Posted - 01/14/2009 :  00:32:55  Show Profile  Visit AADIVER's Homepage
Bottom line: the mainsail slugs on our 250s should be 3/8" diameter, NOT 5/16". So why does Catalina continue to put the wrong size slugs on our mains, often causing blowouts like the topic below? Calling Frank Butler! Oh, I forgot he's in Largo, Florida now and not in Sou Cal.
Frank Farmer
Long Beach, CA
aa.diver@verizon.net
http://mysite.verizon.net/aa.diver
PRETTY PENNY
'01 C-250 WK, Hull #558
Response Posted - 01/14/2009 :  06:22:35  Show Profile  Visit britinusa's Homepage
Frank, curious, where did you get that fact from? (3/8" v 5/16")
AADIVER
Response Posted - 01/14/2009 :  10:51:46  Show Profile  Visit AADIVER's Homepage
Catalina Direct. I believe 5/16ths are installed to facilitate raising and dousing, but 3/8ths are more secure. I anticipate that with 3/8ths a dousing line from the head will be essential; the sail won't drop as easily without it. What say you, boss?
Response Posted - 01/14/2009 :  13:09:50  Show Profile  Visit delliottg's Homepage
I'd think a shot of SailKote before each raising would go a long way towards keeping everything moving properly. Think of it as prune juice for the stick.
AADIVER
Response Posted - 01/14/2009 :  14:54:56  Show Profile  Visit AADIVER's Homepage
Is SailKote only available at WM or Boater's World, or where cheaper? I'll Google it and see what comes up for Long Beach.
Response Posted - 01/14/2009 :  17:29:39  Show Profile  Visit delliottg's Homepage
Either should carry it Frank, or you can get it from Defender or other places like it. It's not cheap, but works well, I use it constantly on the boat to lube whatever seems to need it.
AADIVER
Response Posted - 01/16/2009 :  23:16:10  Show Profile  Visit AADIVER's Homepage
Installed the new slugs and shackles today and sprayed 'em with SailKote; up and down the track smooth and easy. Went for a sail, no problemo's. Easy fix for 20 bucks. Even though the 3/8ths have a bit wider diameter, not a tight fit in the tracks. Again: 250 mains should have 3/8th slugs and not 5/16ths.
Response Posted - 01/17/2009 :  01:58:01  Show Profile  Visit delliottg's Homepage
Frank,
Can you take pictures of your repair? I'd like to see other examples of it before I do it on mine. Thanks!
frogger
Response Posted - 01/17/2009 :  06:00:29  Show Profile
A while back I had a similar experience as Frank with the original plastic slugs breaking or pulling out so I replaced them with the 3/8th slugs and have had no trouble with them. I did, and do, coat them with a silicon lubricant.
bill bosworth
Response Posted - 01/17/2009 :  22:08:21  Show Profile
Frank;
I'm supprised that your main had 5/16 slugs, the main that came on my '95 had 3/8 slugs,(I've had to replace them all). I just got a new catalina main, it also has 3/8 slugs.
Quite a while ago someone on this site suggested inserting a piece of candle in the sail track between the top two sail slugs. The wax is dragged up and down the groove each time the sail is raised. I find that my wax slide lasts one to two seasons and does a great job lubricating the track. It's a great no cost improvement.
Bill c250 #134 Serendipity
on Kerr lake NC
Edited by - bill bosworth on 01/17/2009 22:09:52
AADIVER
Response Posted - 01/19/2009 :  00:59:13  Show Profile  Visit AADIVER's Homepage
Damn, Bill, I wish I'd read your candle wax post before I spent 10 bucks on a can of SailKote. I got it from WM, so I'll try and return it ;-)
Response Posted - 01/19/2009 :  13:07:00  Show Profile
Keep the Sailkote. I use it for all sorts of stuff (hinges, etc) in the house. The stuff is remarkable. We had some bi-fold doors that nothing could make run smooth. A spray of Sailkote fixed it. Magic.
