PS tested a bunch of stabilizers recently, and none of them had significant effect on stored fuel. The concept of fuel sitting in a car's fuel tank for a season would be pretty bizarre. Several of the products had some short term benefits, but the cost/benefit value of these products is generally marginal. They don't hurt, so use them it it makes you feel more secure, but don't expect them to really prevent phase separation in your spare tank. I address that issue by using two 3 gal. tanks and filling the second one when the first is below 1/2 full or when starting a longer cruise.
Every additive product claims the same thing... I've talked to mechanics and e-mailed engine makers, and nobody has a definitive answer.
You guys have it easy, as I once did! Just don't keep your few gallons of gasoline around for more than a short season. I now have a 110 gallon tank (have your fun with me!) and face some interesting options for the winter: (1) Try to run it down to a very small number without running out... (2) Fill it all the way up to minimize the air-space that fosters condensation and therefore water pollution, and add stabilizers, or (3)--recommended this year--fill it half way, stabilize the hell out of it, and then fill it with fresh gas at the beginning of next season. But I'm talking about a considerable amount of fuel in a built-in tank. You folks should just dump the few gallons into your cars/trucks now and then, and start afresh. (Two gallons into 15 is pretty safe.) Don't risk your carbs for a couple of bucks worth of gas!
The other safeguard is to install a Racor water separator, as I did in Passage. This assumes that no matter what you do, ethanol will absorb and then release some water, and it will wreck your carb. It's a new world.
