I purchased a MXCP25 AM/FM/CD Stereo Package used off of Craigs list. It's all there, but I don't have the manual. There are many wire leading from the main unit as well as from the speakers. Can anyone send me a manual or send me to on online so I can make the installation.
Thanks - Bob
Bob Grace Castleton, Vermont 1984 Swing Keel "Sara"
Not exactly sure of your stereo, but normal wire colors are: yellow- constant 12V + (to keep the memory) red- switched 12V + (to turn it on) black- 12V - green- left rear speaker + green w/stripe- left rear speaker - purple- right rear speaker + purple with stripe- right rear speaker - white- front left speaker + white with stripe- front left speaker - grey- front right speaker + grey with stripe- front right speaker - blue- remote turn on for amp
I have a Dual MXD41 radio. Here are the wiring specs from my booklet and almost the same as the text above:
yellow- constant 12V + (connect directly to battery circuitry to keep the memory) red- connect to switched 12V + such as aux switch on fuse panel (to turn it on) black- 12V - (connect to neg bus bar to ground) blue - remote turn-on (connect to amp or power antenna. Insulate if not used. I didn't need it) green- left rear speaker + green/black (w/stripe)- left rear speaker - violet(purple)- right rear speaker + violet/black (purple with stripe)- right rear speaker - white- front left speaker + white/black (w/stripe)- front left speaker - gray- front right speaker + grey/black (w/stripe)- front right speaker -
