 Tiller Extensions
B Baldwin
Initially Posted - 02/05/2009 :  17:48:10  Show Profile
What's the best manufacturer & size for a tiller extension for:
Racing
Cruising
Racing/Cruising
Spring's coming, I need easier access to my cabin top winches & rope clutches.
Brad B
3123 Swing Keel
"Magic"
Response Posted - 02/05/2009 :  18:04:09  Show Profile  Visit delliottg's Homepage
We've got a [url="http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/2437?&cid=chanintel&ci_src=14110944&ci_sku=2437"]Forespar tiller extension[/url]. It pops and locks into a fitting that's drilled & screwed into the top of the tiller. A quick twist of the wrist lets you adjust it's length.
Response Posted - 02/05/2009 :  20:48:10  Show Profile
One word...Autopilot!
Response Posted - 02/05/2009 :  20:52:40  Show Profile  Visit delliottg's Homepage
We got one of those too!
Response Posted - 02/05/2009 :  22:32:51  Show Profile  Visit piseas's Homepage
I have both as well but use for different situations.
I use the tiller extension, Forespar, while sailing in the catbird seats. I have the one that extends to 30+" but wished I had the longer one.
I use the autopilot as an extra crew member while either sailing solo or on long trips to break the monotony.
Edited by - piseas on 02/05/2009 22:35:56
Response Posted - 02/06/2009 :  08:25:33  Show Profile  Visit Prospector's Homepage
I have an autopilot, but am wary of using it. I just don't trust it in anything beyond a dead calm. Too many times it has veered off sharply, sending me to some bazrre new destination.
I have a tiller extension but have yet to install it. I should add that to my to-do list...
Response Posted - 02/06/2009 :  09:46:55  Show Profile
The Catalina 25 is very unfriendly to the whole tiller extension thing. I have used Forespar tiller extensions on all of my boats and the C25 has the worst cockpit for finding a place to perch where an extension can really help. The problem is how narrow the cockpit is. If you sit forward the angle of the extension is terrible, out to the side and you can't really get far enough away to use it well. A shorter extension would be better but I do not know of any "half length" extensions.
Response Posted - 02/06/2009 :  09:49:39  Show Profile
<br />I have an autopilot, but am wary of using it. I just don't trust it in anything beyond a dead calm.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
There may be something amiss with your autopilot, or its installation, because spontaneously veering off sharply is not a designed feature of autopilots. Autopilots show their true worth, especially when singlehanding, in conditions that require constant attention at the helm.
Both of these videos were shot with my autopilot at the helm.
[url="http://video.google.com/videoplay?docid=4536671289105007193"]Autopilot in action[/url]
[url="http://video.google.com/videoplay?docid=2937627551303966063"]Sailing in a breeze with autopilot[/url]
Response Posted - 02/06/2009 :  10:05:21  Show Profile  Visit delliottg's Homepage
Chris,
From your description, it sounds like the calibration for the fluxgate compass is off. There are various methods of doing the calibration, but all of them involve either sailing in large circles (actually motoring is better) that take a couple of minutes to complete, or in the case of my handheld, taking eight shots over a period of about two minutes, 45° apart from each other. Once done, you generally don't have to do it again unless you've moved quite a distance (the magnetic field of the earth isn't constant), or if you've had to replace the batteries (EG: in my handheld).
Go through your manual and make sure you've done the calibration properly, once done, your boat should be able to hold a very steady course for you. If you've done the calibration and it still veers off, I'd go through any troubleshooting steps your manual might suggest, and failing that, give the manufacturer a call.
Oh, and don't mount it near any magnetic stuff like cockpit speakers, too close to your outboard (magneto or alternator will throw it off), VHF, etc. Any of those can affect the calibration, as will any ferrous metal in proximity to the compass, especially if it's not always there, like a sheath knife, pocket full of keys, etc.
Hope this helps, you should be able to trust your AP.
Response Posted - 02/06/2009 :  10:20:58  Show Profile  Visit Prospector's Homepage
Thanks for the tips David. I actually blamed it on the batteries on the boat not bein gcharged (I had a load of battery problems last year). This season I will re-calibrate the AP and see if it performs any better.
Ours is a Simrad (I think) and plugs into the boat. By "Batteries in your handheld" are you talking about hooking up a GPS to your AP? I don't think ours hooks up that way. If I am wrong, then that my be my problem! Maybe it was steerin gto nothing, and thought it got there.
Dammit - I think I managed to hijack the thread again.
Ok Folks back to Tiller extensions.
