 VHF Radio/Antenna/Autopilot Dilemma
Previous Page | Next Page
Page: of 4
Response Posted - 02/11/2009 :  15:39:33  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JohnP</i>
<br />The main reason to get an auto-inflating PFD is to protect yourself if you hit your head and fall overboard unconscious.
Actually, in the case of being knocked unconscious, you would want to be wearing an inherently bouyant pfd because if there was a malfunction with the auto-inflate mechanism, you would be unable to use either the manual or oral inflator.
Response Posted - 02/11/2009 :  15:49:11  Show Profile  Visit Prospector's Homepage
I hate to say it, but I just don't "get" the rage ovre these self-inflating PFD's. I wear my canoeing life Jacket all the time If I'm on the boat. same with everyone else in our family. They work. They can't fail (unless you don't put it on right), and they aren't all that bad if you buy a quality one.I guess its just one more way I think different than a lot of folks.
Response Posted - 02/11/2009 :  16:27:49  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JimB517</i>
<br />No one has mentioned the reasons for putting the antenna on the stern pulpit, like I have done.
(1) it's easy
(2) it's cheaper
(3) you can service it
(4) you can get a much better 8 foot antenna
(5) you can reduce weight aloft
(6) you can hook your handheld up to it in an emergency with a patch cord
(7) Transpac, etc. requires an antenna NOT on the mast (dismasted, you still can communicate).
(8) nice place to hang your class flag
(9) your long coax run to the top of the mast significantly decreases RF power unless you have expensive low loss cable.
6 DB antenna on the rail, 3 DB antenna aloft, I get just as good range and signal with my rail mount.
Frankly I would not leave home without either: tiller pilot AND 2 VHF radios (fixed and handheld). Plus I always carry my cell phone.
I thought you had mentioned these sometime in the past! Do you know about how far you can TX and RX? What make/model radio/antenna do you have?
Thanks for the update!
Response Posted - 02/11/2009 :  16:37:25  Show Profile
Don,
You're right! I guess that's why I have one hand for the boat at all times when I'm up at the bow bouncing around in 3 to 5 foot waves. I refuse to fall off.
But in terms of planning ahead...
...as John Rousmaniere says in his sailboat safety videos, something like 80% of all boating drowning fatalities are recovered with their zippers down.
Response Posted - 02/11/2009 :  18:49:15  Show Profile
<br />I hate to say it, but I just don't "get" the rage ovre these self-inflating PFD's. I wear my canoeing life Jacket all the time If I'm on the boat. same with everyone else in our family. They work. They can't fail (unless you don't put it on right), and they aren't all that bad if you buy a quality one.I guess its just one more way I think different than a lot of folks.
Come on down to Houston, TX in August and you'll see why a light weight PFD is a must. 95% humidity and 100 degress is not that uncommon. And you sure don't want to get in Galveston Bay uinless you like to glow in the dark!
Edited by - GaryB on 02/11/2009 18:49:58
JimB517
Response Posted - 02/11/2009 :  18:59:52  Show Profile  Visit JimB517's Homepage
Gary, I have no problem talking 25 miles on my fixed VHF and can sometimes hear much, much longer (50 - 60 miles). My 1 to 5 watt handheld - it is a crap shoot to even talk 1 mile sometimes.
My antenna is a 6 DB gain Shakspear from West Marine for about $100. It is the kind with an internal copper conductor. I'd avoid the 9 DB gain. The antenna sits on the stern rail. The co-ax comes in through the clamshell vent, runs through the internal compartments above the quarter berth and pops out just behind the radio. My radio is mounted above the quarter berth right at the salon.
Response Posted - 02/11/2009 :  19:25:25  Show Profile
<br />Gary, I have no problem talking 25 miles on my fixed VHF and can sometimes hear much, much longer (50 - 60 miles). My 1 to 5 watt handheld - it is a crap shoot to even talk 1 mile sometimes.
Thanks Jim! I appreciate the info. This is a dumb question, but what's the gold rod with the orange whatever?
Response Posted - 02/12/2009 :  09:13:56  Show Profile
That's a man-over-board pole and pennant, held on the backstay.
JimB517
Response Posted - 02/12/2009 :  12:41:37  Show Profile  Visit JimB517's Homepage
correct, you can also see my lifesling.
Indiscipline is fully equipped for offshore coastal racing (not transpac). Transpac requires carrying a 2nd rudder, among other things.
Response Posted - 02/12/2009 :  16:46:27  Show Profile
Jimb,
What make/model is your fixed mount radio?
Response Posted - 02/14/2009 :  17:17:58  Show Profile
For you lake sailors who want an inexpensive antenna to attach to your VHF radio, consider one of the "emergency" rubber ducky antennas with a suction cup on the bottom (available at WM, etc.) I leave mine laying on the shelf behind the starboard settee not far from the radio and it gives me all the reception I need, for well under $50, and it is not exposed to lightning!
JimB517
Response Posted - 02/14/2009 :  18:28:00  Show Profile  Visit JimB517's Homepage
I've just got an old West Marine brand, someday I'll replace it, however it works fine. I was able to check in to race control in Newport Beach from off Catalina at least 25 miles away one day.
Response Posted - 02/15/2009 :  10:30:54  Show Profile
<br />I've just got an old West Marine brand, someday I'll replace it, however it works fine. I was able to check in to race control in Newport Beach from off Catalina at least 25 miles away one day.
That was probably a shore based transmission with much higher wattage as is sometimes licensed for commercial use, i.e. Tow Boat US guys have mega power too. They might be able to pick up your handheld as a result, but the line of sight rule still applies. I have heard of electronics guru's putting an amplifier of sorts in line to boost power when wanted for offshore buddy boating sans SSB. Near shore you have to turn it off as you'll hear every transmission for 200 miles.
With our 58' mast, plus antenna, we have been heard as far away as 47NM - just to put it all in perspective. We have heard transmissions from further away than that, but were not readable when we responded.
sten
Response Posted - 02/15/2009 :  11:43:49  Show Profile
Sten... Regarding "line of sight", from the top of your 58' mast, the horizon is only approx. 10 miles away. [Rule of thumb: Horizon = sqrt(7/4*height)] The top of another 58' mast would be able to "see" the top of your mast from no further than 20 miles. So VHF waves are most certainly bending over the horizon, as well as over land masses to some extent. Both transmission power and receiving sensitivity are factors, as are water versus land, sunspots, and who knows what else.
Edited by - Dave Bristle on 02/15/2009 12:06:09
Response Posted - 02/16/2009 :  09:52:30  Show Profile
Agreed Dave and thanks for the math lesson. Radio waves do bend and bounce... SSB for example bounces off of the stratosphere enabling long distance communication. Most VHF shore based operations and the Coasties have tall antennas nonetheless, thereby increasing their range.
sten
Response Posted - 02/16/2009 :  22:20:21  Show Profile
The Coasties also have much higher-powered transmitters and I assume amplified receiving gear. I've experienced evidence of both.
Response Posted - 02/17/2009 :  18:23:49  Show Profile
Regarding the Wham Mic range in COG event: the antenna for the Wham is in the module that connects the radio, so penetrating the fiberglas with the handheld limits the range. I tried controlling the radio from the dock and got "iffy" performance at 40 feet and reliable performance at 30 feet from different locations; you would certainly have no more than 30 second to flip the distress button, and probably significantly less.
Response Posted - 02/18/2009 :  11:38:25  Show Profile
Well, I ordered a Mustang MD3084 auto-inflate PFD w/harness from Defender yesterday. Also ordered a stobe to go with it. All should arrive next Tuesday.
http://www.defender.com/product.jsp?path=-1|135|439|320546|436864&id=337833
http://www.defender.com/product.jsp?path=-1|135|320544|9312&id=122677
My first experience with Defender was very pleasant. Very courteous and patient person on the phone. They had this PFD on sale last week for the Miami Boat Show. I couldn't get online to order it last week and when I explained the situation they were kind enough to offer me the sale price if I ordered then and there. They didn't have to do this but by doing that they made a customer for life.
Now I've got to start saving for my radio and antenna!
Response Posted - 02/18/2009 :  16:48:17  Show Profile  Visit piseas's Homepage
Gary, nice choice and I like Defender as well. But what about a tether to keep you on the boat? Unless that's down the road. Guess you wouldn't buy jacket with harness unless planning to get tether, right?
Edited by - piseas on 02/18/2009 16:50:04
Response Posted - 02/18/2009 :  20:08:38  Show Profile
I can buy tethers through the company I work for at 5% above cost. Should be able to save at least $50-$75 bucks.
Response Posted - 02/19/2009 :  15:13:44  Show Profile  Visit piseas's Homepage
Gary, that is great. Hey who do you work for? Maybe we can get you some business on the side!
Response Posted - 03/03/2009 :  20:51:40  Show Profile
Should I go with a single leg or double leg tether? Whichever I go with I'm going to go with the retractable type. I assume I should be looking at the 1 meter retracted/2 meter extended?
I'll be sailing solo most of the time.
Thanks in advance for your help and support!
Response Posted - 03/03/2009 :  21:42:13  Show Profile  Visit delliottg's Homepage
We both have the duals tethers with the 1 & 2 meter shock corded lanyards. For the difference in money versus the ability to stay connected to your boat at all times, it seems worth it to me. I have to admit I've yet to use both tethers at once, but we've only been out twice this year so far, and both times in very mild conditions with at least two people on the boat. What I've started doing is attaching myself to the mast with my six foot tether while I work the foredeck or the main. I almost never remember to disconnect myself until it yanks me up short about the time I want to step down into the cockpit. Practice, practice, practice.
Response Posted - 03/05/2009 :  14:55:57  Show Profile  Visit piseas's Homepage
Gary, if you have a jackline from bow to stern, and are always connected then only one is necessary. If this is not the case and you have attach yourself to another point then 2 is best. That way you are always attached to something.
Tradewind
Response Posted - 05/25/2010 :  12:59:03  Show Profile
I know I've seen some great pics on the forum for running VHF wire up the mast for the 250, can't seem to find the pics anywhere. I think they were posted by Randy or Dave on the 250 Forum....Help?
Page: of 4 Previous Topic Topic Next Topic
