I first want to thank Derek for his simple description in another post regarding reading jib telltales for proper jib car positioning. I tried it and found that my cars were generally too far back and I was loosing significant power from the upper part of my jib. I moved them forward and it really seemed to help.
So I now want to add telltales to the sail for my sailing dinghy. There is only one sail (no jib). Should I put the telltales on the leach, like those on my C25 mainsail? Should I instead put them about a foot back from the luff, like those on my C25 jib?
Separately, I had Dair Sails (Wilmington, CA) put a window in the dinghy sail. Boy, what a difference -- it's like I took off my blindfold! While I don't really have any experience with sail lofts, Dair seemed to be a great place. They did it for a very reasonable price and they beefed up some other weak areas they found at no charge.
I would put them both places. The telltales that are a foot aft of the luff tell you what the air is doing as it passes over both sides of the sail, and the ones on the leech tell you what the air is doing as it leaves the leech. Both provide valuable sail trim information.
If you would like to place tt on a main they should be places about 1.5 feet from the luff and about 2-3 feet above the tack. Those help with steering. you can also place on on the top batten so you can tell if you are stalled out.
Laser sailors have telltails about a foot back from the luff and at the leach. Don't have the telltails too close to the luff as the mast stirs up the wind quite a bit and the telltails would be useless. About a foot back from the luff would be a minimum to get any proper reading. I've also seen people put another set of telltails half way between the luff and leach telltails. This may be overkill though.
