 Yr. 2000 C250WK Rub Rail Problem
jkey6
Initially Posted - 10/02/2002 :  16:22:40  Show Profile
Is anyone else having trouble cleaning the factory rub rail. Odd problem, the light grey material seems to now have spots of black mold IN it. It will not wash off.
I noticed the problem soon after I launched in April 2000 and it continues to get worse. I tried all types of cleaners and they seem to have absolutely no effect. I really think the discolorization is 'behind' or in the material itself.
Sure looks bad on a boat that otherwise looks just like it did the day it arrived from Cat.
Any ideas are appreciated.
JKEY6 on "All Keyed Up" Hull 447, Cat 250WK.
cathluk
Response Posted - 10/03/2002 :  09:22:36  Show Profile
Our '97 also has the black mold. We've never been able to get all of it off, but have not tried any really strong cleaners or solvents because we'd rather live w/ the black rubrail than damage it.
If you find something that work, please let us know.
Cathy
"Blown Away"
'97 C250WK #253
MarkTM
Response Posted - 10/03/2002 :  09:41:43  Show Profile  Visit MarkTM's Homepage
I've had some success with Softscrub w/Clorox. It still takes quite a bit of muscle to remove the stuff.
Mark Melchior
C250wb "Lorelei" #384
[url="http://www.texassailor.com/"]<img src="http://www.texassailor.com/texas.gif " border=0>[/url]
<font size=1>(click flag to visit Central Texas Sailor)</font id=size1>
DougA
Response Posted - 10/03/2002 :  12:37:46  Show Profile
My 96 had the same problem. I tried several cleaners with no luck, I tried Acetone on a small spot and it worked but was very slow. I just coated the hull with Poli Glow and the cleaner that came with the kit worked. Rub rail is nice and clean now. I don't have the bottle at work so I can't tell you what's in it but the labe cautioned you to wear gloves supplied with the kit. The Poli Glow on the hull looks great.
Doug A., C250wb, San Franciscp Bay area
n/a
deleted
Response Posted - 10/03/2002 :  12:55:37  Show Profile
The cleaner supplied with poli-glow is a "Butyl" based water soluble cleaner. If the smell is familiar, that's the "butyl". Simple green is a mild version of a butyl cleaner. West Marine and Boat US may have CRC's "Marine Clean H.D." that's a stronger version. Also CRC has their industrial versions call "Heavy Duty Hydroforce", which is veerry strong yet mild enough to be safe on rubber and plastics".Also Mary Kate Marine products has their "Spray Way All purpose cleaner" that too is a very strong "butyl" cleaner.
Sorry to get carried away, chemical composition of cleaners and lubricants is how I pay the bills.
Gclarke C250 WB...Left coast
Ben - FL
Response Posted - 10/03/2002 :  20:52:10  Show Profile  Visit Ben - FL's Homepage
Q: What is so simple and green about Simple Green? I was thinking it was a combination of baking soda and vinegar. And does baking soda and vinigar make a good cleaner together? Don't they neutralize one another?
BTW, is bleach bad for gelcoat? That is generally what I use. Spray on with a garden type sprayer and let set. Then hit the deck with the brush.
Found this:
[url="http://www.safe2use.com/kleen/clean2.htm"]non-toxic cleaners[/url]
Please let me know your opinions.
Thankx,
Safe voyages,
Ben, FL s/v Chick-a-pea C250wk
Edited by - ben - FL on 10/03/2002 21:01:11
Response Posted - 10/05/2002 :  09:21:32  Show Profile
I use bleach.... but it doesn't take much... perhaps a half cup in a pail of water along with the soap. The purpose of the bleach of course is not a cleaner but rather to kill mildew... and not much is required to do that. An excess concentration runs the risk of doing damage to halyards, sheets, interior cushions if it should reach them...etc.
It does take the bleach a few minutes to do its job...so time rather than more is the key.
Arlyn C-250 W/B #224
ssteakley
Response Posted - 10/06/2002 :  22:05:23  Show Profile
I have used a couple of different cleaners...on the forum one guy suggested "Goof Off", it works but someone else said it was not to good for the rubber, then I tried those green scotch pads with water, and it comes right off...I then waxed them and they have stayed clean for months...I still get a few black spots, but I just go over with a scotch pad with water and it is clean again.
I am one of those guys that could care less if my vehicle was not so clean but my boat shines...I do not spare the wax and I really like the 3M products,
Steve Steakley
Edited by - ssteakley on 10/06/2002 22:05:55
jkey6
Response Posted - 11/04/2002 :  09:37:59  Show Profile
G. Clarke - thank you very much for your expert recommendation to use a 'butyl' cleaner on the rub rail.
WoW! Hard to believe how well it worked. Over the summer I scrubbed the soft rubber hard enough with all sorts of cleaners to destroy it and it still looked bad. I used soap, bleach- you name it.
Over the weekend I sprayed it with Simple Green, and rubbed it with a 'scrunge pad' and got instant clean.
Thanks again - it looks like new!
JKEY6 on 'All Keyed Up'
C250WK, #447.
