 Stove removal
John P
Initially Posted - 04/01/2009 :  07:41:44  Show Profile  Visit John P's Homepage
So, I am thinking of removing the old stove entirely and unsure what to do with the space. Was thinking at one time of setting up the electronics in that area:
-VHF
-Stereo
Anyone come across any creating ideas when removing the stove?
'84, C-25, SR/FK, #4663, "ILLUSIONS", Chazy, NY (Lake Champlain)
http://www.sailblogs.com/member/illusions
Response Posted - 04/01/2009 :  09:07:30  Show Profile
I put teak battens across the front and used it for what ever seemed appropriate at the time.
glen
Response Posted - 04/01/2009 :  09:54:30  Show Profile
We replaced ours with one of those counter top ranges, and love it, but we have shore power at the dock
John P
Response Posted - 04/01/2009 :  10:10:57  Show Profile  Visit John P's Homepage
INteresting ideas guys! Thanks!
Response Posted - 04/01/2009 :  10:42:01  Show Profile
I removed the stove and installed a microwave oven which is used more for storage that for heating anything. Strapped on top of the microwave is my boombox.
Response Posted - 04/01/2009 :  11:43:15  Show Profile
I removed the PO's butane stove and installed a 12" high plastic catch-all bin that we use mostly for un-refrigerated food and supplies.
Response Posted - 04/01/2009 :  12:50:30  Show Profile
I've removed the original alcohol stove, but kept the cutting board. Using the space below the board for drink holders and other small item until I decide a more permanent solution.
Happy D
Response Posted - 04/02/2009 :  16:42:41  Show Profile
[url="http://www.johnvining.com/newstove.html"]John Vining[/url] installed a propane oven in that spot and did an awsome job.
Edited by - Happy D on 04/02/2009 16:50:21
Deric
Response Posted - 04/03/2009 :  20:54:28  Show Profile
Wow, John Vining did a great job putting in an oven/stove. I spend so much time sailing, and working
on the boat, that if I had an oven/stove, I wouldn't know how to use it.
I'd have to learn how to cook, or get someone to cook for me. hahaha right.
Deric
Response Posted - 04/05/2009 :  08:27:52  Show Profile  Visit OLarryR's Homepage
John,
If I removed the alcohol stove on my boat, I would probably put a small micro-wave in that area.
The VHF radio ---actually there are few areas in the cabin that make it any better than another unless perhaps it was located right up against the companionway facilitating it's use when single-handed sailing and in the cockpit area. My VHF is right now located behind the steps and that is not the greatest area if needed and I am in the cockpit. The two possible improvements I would consider for my VHF radio functionality would be to either a) Get a new VHF and locate it similar to where it is now but have an optional wired remote to it from a quick-disconnect in the cockpit area. That way I would have full functionality and be able to hear it from the cockpit area. b) I would leave existing radio as is and buy a portable VHF unit to use in the ccckpit area.
The stereo - Well, so far, my little mini-boombox is okay and easily stored out of the way when not used. If I were to replace it, I would probably try to build a stereo into a side wall adjacent to the quarterberth area...starboard seating area. Kind of get it off to the side.
From what I recall the times we have gone sailing, perhaps if you removed your stove, you could use that area for two purposes: Either a microwave, VHF or Stereo but if at all possible, build upon a base that allows also a storage area within it. You have a lot of supplies and what not and I just not sure where you will put some of the things. Removal of the stove provides options to accomplish a combo of benefits.
Edited by - OLarryR on 04/05/2009 08:29:18
cat25
Response Posted - 04/12/2009 :  05:57:53  Show Profile
I removed the burners from the stove. THen pluged the holes with half inch bolts. Then i put a can of sterno in each side where the existing burners were. They fit there perfect. They are the larger sterno you can get at party stores. Ken
Response Posted - 04/12/2009 :  11:07:57  Show Profile
cool
