 Spinnaker-v-Gennaker
sdk
Initially Posted - 04/11/2009 :  08:35:10  Show Profile
OK,
I have a '85 Catalina 25 swing keel and would like to add a Gennaker/Spnnaker since the area where I sail(the Potomac) tends to have very light winds during the summer and my 130% jib is often too heavy to work the light winds.
I don't necessarily want to add the whole whisker pole etc, partly because I single hand and dont want the extra "stuff" so I thought a Gennaker might work.
I'm not sure what I need, how to rig it or even if this is the best way to go.
I'm looking for any advice you all may have.
Response Posted - 04/11/2009 :  10:17:02  Show Profile
A gennaker, also known as a cruising or asymmetrical spinnaker, would be a good choice for your purpose. To rig it, you should have an extra halliard to raise it, and a downhaul to adjust the tension on the luff. Both the head and the tack of the sail should be attached forward of the headstay. We had a discussion of the means of rigging it at the following hyperlink: http://catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=19352& SearchTerms=cruising spinnaker
I attached the tack of mine to an adjustable downhaul, so I can adjust the tension on the luff. You'll need extra long sheets for it. A chute scoop, also known as a spinnaker sock, isn't necessary, but it makes it much easier to raise and lower singlehanded.
Ebay is a good place to buy one, but you have to wait patiently until one comes up for sale that fits the C25, and then you have to submit a winning bid. Often, they are sold on Ebay with a chute scoop.
Bill Holcomb
Response Posted - 04/11/2009 :  10:30:03  Show Profile
I've owned an '85 C25 since she was a new boat. And, have a cruising spinnaker for her. It's set up just about how Steve notes above. In addition, I've got a 155% Drifter Jib. This jib is made out of 1.5 oz. spinnaker cloth (ripstop nylon). I still use hanks, so my drifter is hanked onto the forestay just like a "normal" jib. If you've got roller furling for the jib, you could rig a second halyard (like for the spinnaker) and hoist the drifter "flying" and not hank it on to the forestay. You'll only use the drifter in light winds - so luff sag isn't a problem.
The biggest advantage to the drifter is that it sails upwind just like any other jib. And still sails off the wind nearly as well as a cruising spinnaker.
sdk
Response Posted - 04/11/2009 :  10:48:24  Show Profile
Thanks for the good info all.
I do have a roller furler and was wondering how the tack would mount with the drum in the way. Im thinking a sheet run through a block on the bow (outside the pulpit) would work?
Also, I have a tall rig, so any suggestions on luff/leech/foot lengths and what weight of fabric should I look for?
Response Posted - 04/13/2009 :  09:54:59  Show Profile
I have attached a block at the stem fitting so that I can adjust the 4' steel cable (pennant) attached to the tack of my gennaker. Then with a line led back to the cockpit, I can adjust the height of the foot of the gennaker.
My gennaker came with the boat, and it has a dousing sock. This gennaker sock makes it straightforward to fly the sail single-handed if you can hold the boat on course and leave the helm for a minute or two and it makes it much safer, in my opinion.
Response Posted - 04/13/2009 :  10:12:02  Show Profile
from another post...
I like a large drifter to provide light air power with a 135 roller furling head sail. 170% or so, 2 or 3 oz ripstop, and no hanks. I would simply use a spare halyard to hoist it free of the forestay. In the conditions where this sail gets used, free flying the luff lets you really soften the shape and catch a lot of air. Here is a photo of mine in a turtle, note the glass conditions, I had just come in from sailing while others were bobbing.
edit: note the dual genoa cars, drifters rig like a genoa so the hardware is easy.
