99% Isopryl Alcohol in the pharmacy at 1.29 a bottle will work. Just won't burn hot enough as previously noted. However, it's an alcohol stove, it won't burn hot no matter what you do.
I've decided my little Kenyon butane is soooooo much nicer than my expen$ive Origo was. It cost me less than three quarts of that WM alcohol. About 50% more heat, better control, no smell, no spilling,... A $5 pop-in cartridge cooks for 3 hours.
Dave, I found the Kenyon Express II, looks like what I am looking for. Are you able to find the butane refills locally? Do you store the butane cartridge in the stove/ in cabin when not in use, or on deck/ elsewhere like a propane canister?
<font face="Comic Sans MS"><font size="2"><font color="navy">I use the [url="http://www.amazon.com/Burton-Portable-Table-Butane-Stove/dp/B0000DI5GD/ref=pd_sbs_sg_2"] Max Burton Portable Table Top Butane Stove[/url] and it is plenty hot. It's $30 at Amazon. I took the “curtain burner" out and tossed it. I kept the cutting board and use the space under it to store the stove and some pots and pans. I made a false front that looks like a drawer but is held in place with Velcro to dress up the opening. I keep spare canisters in the lazarette.
Underlined words are <font color="red"><b>HOT</b></font id="red"> links. </font id="navy"></font id="size2"></font id="Comic Sans MS">
What we do is place one of the companionway boards across the cockpit at the transom of the boat. One settee becomes the prep area, and the othre is the finished meals area. If its rainy out, we throw a tarp over the boom, and put a boathook or two crosswise on it to hold it out. Our cockpit becomes a nice little kitchen tent.
Since the little butane stove is so portable, we can also take it ashore for picnics, etc. One improvement we have made though is that we borrowed the "heat sheild" from our MSR backpacking stove, which is basically a piece of aluminium flashing you wrap around the pot to keep the wind from blowing the heat away. It makes a big difference in our cooking times when we have it.
We also still use the MSR backpacking stove to boil water etc., however it is pretty tippy and not suited to sailing very well. In order to get it to work, we have used the winter camping "trillium" heat sheild bolted onto a 3/4" piece of plywood, and the stove bolted onto that to dissipate the bottom heat from the stove (AKA the Afterburner since its so loud) We really only use that stove to boil water for coffee or to warm baby bottles though.
Having a family of 4 aboard, we find that the bigger working space of the cockpit, and having 2 burners is quite necessary. We count ourselves lucky to have a load of compact gear from Canoeing/backpacking, and try to make as much of it transferrable to sailing as possible.
If you choose to use a backpacking stove, I would suggest that you get very comfortable with it onshore before trying to use it aboard the boat, as some of them have a lot of "personality", although different quirks from the curtain-burner that came with the boat. The single worst feature of backpacking stoves is that they tend to be top-heavy, and want to dump your pot of food with the very least provocation.
BTW - for the folks up here - you can get the stove Peregrine is advocating and its fuel cartridges at home hardware at a suitable upcharged price... $31 CAD
And the fuel is available for $10 for a four-pack. Last summer we went through 2 of these for the stove and lantern. Our refills go in the "seat storage" on the Starboard side of the cockpit. None have leaked yet but you never know. I have considered adding loops to the top of the fuel locker and storing them there instead.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Prospector</i> <br />Peregrine, we use one of those too.
If you choose to use a backpacking stove, I would suggest that you get very comfortable with it onshore before trying to use it aboard the boat, as some of them have a lot of "personality", although different quirks from the curtain-burner that came with the boat. The single worst feature of backpacking stoves is that they tend to be top-heavy, and want to dump your pot of food with the very least provocation. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Beautifully written, and very accurate. Isn't micro yachting great? I guess that is what they would call it these days. It used to be normal?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Windhover</i> <br />Dave, I found the Kenyon Express II, looks like what I am looking for. Are you able to find the butane refills locally? Do you store the butane cartridge in the stove/ in cabin when not in use, or on deck/ elsewhere like a propane canister?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
As you can see, it's virtually identical to Peregrine's (although shown here with the case)--probably just different labels. WM, Defender, and my local hardware all have Kenyon refills, and I've seen them at marinas. Per the instructions, I remove the cartridge from the stove and store it in a cockpit locker. If it were the C-25, I'd put them in the starboard rope locker or the port fuel locker--not in the "dumpster" (which is open to the bilge). Like propane, butane is heavier than air and flows to low spots. I also bought their pot-holder for security, since it isn't gimbaled.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Bristle</i> <br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Windhover</i> <br />Dave, I found the Kenyon Express II, looks like what I am looking for. Are you able to find the butane refills locally? Do you store the butane cartridge in the stove/ in cabin when not in use, or on deck/ elsewhere like a propane canister?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
As you can see, it's virtually identical to Peregrine's (although shown here with the case)--probably just different labels. WM, Defender, and my local hardware all have Kenyon refills, and I've seen them at marinas. Per the instructions, I remove the cartridge from the stove and store it in a cockpit locker. If it were the C-25, I'd put them in the starboard rope locker or the port fuel locker--not in the "dumpster" (which is open to the bilge). Like propane, butane is heavier than air and flows to low spots. I also bought their pot-holder for security, since it isn't gimbaled. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
<font face="Comic Sans MS"><font size="2"><font color="navy">Dave, They do look the same and the Max does come with a case. The only difference I can see is the Max seems to sell for $10 - $12 cheaper and is black instead of camo.</font id="navy"></font id="size2"></font id="Comic Sans MS">
Hi, The Alcohol for the stove can be bought at any hardware store, it is usualy with paint remover. Make sure you get the right one. Denaturated Alcohol, and it is written for marine use.
Boy O Boy !!!! can't wait to put back the boat in water.... winter is toooo loonnngggg up north.
