I and others who have sailed my 250WK noticed that my boat points better and is slightly faster on a starboard tack (especially noticeable when close hauled) than on Port Tack. My Mast is in column and the rigging is equal in tension on the shrouds (ie lower shrouds are the same tension port & Starboard as well the uppers). The port lower shroud is slightly looser when on starboard tack than the Starboard lower is when on port tack...but the mast is in column... any help in figuring this out will be much appreciated. Moon Chaser has never sailed better but I think there is more I can do when it comes to tuning the rigging, Steve Steakley
Steve - very carefully sight up the mast track. You may find that the mast head is very slightly hooked, even tho' on fore & aft and on side to side appearance it looks to be in column. This is probably the commonest cause of such a speed differential. Derek
You describe an often in the past lament of C25 owners... My guess is that there is some symetry difference in the hull. I say this because it seems that you have verified the above the water symetry are equal.
It seems to me that casual observations (which usually are fairly indicitive of reality) could be verified on some occassion on a lake with no favored chop and constant wind direction. Take GPS of track and compass point of the boat at equal speeds of each close hauled tack. Record exact point of the wind direction. Ideally...each tack will be equal degees from the wind...variations will confirm your suspicions.
This is often a significant observation of C25 swingers when the keel pivot pin has wollered or the its been rebuilt and rebored slightly out of line. Any misalignment actually doubles the differential between tacks and will cause the effect that you describe.
Check the latteral boat balance also by using a level on the mast to check plumb. The assumption is that the mast is centered using the main halyard...rather than equal turns on rigging....which could have differing lengths.
Derek and Arlyn Ok, thank you. I wonder if weight distribution in the cabin can have any effect..I store lots of stuff in the lokers below the port and Starboard setee's and I know the stuff in the Port side is heavier...Should I try to balence the load? Steve
"It seems to me that casual observations (which usually are fairly indicitive of reality) could be verified on some occassion on a lake with no favored chop and constant wind direction. Take GPS of track and compass point of the boat at equal speeds of each close hauled tack. Record exact point of the wind direction"
Arlyn - Steve would have a very hard job trying to do this on Canyon Lake. Our wind shifts constantly...if you manage to sail 50 yards without a wind swing it's a good day! The lake is surrounded by hills and valleys which make the wind do weird things! I've been close hauled on starboard 10 yards behind a boat close hauled on port and we were both on the same heading. I've run to the leeward mark wing & wing and met a chute coming the other way. Once went from stbd tack to port without the bow changing direction. I was once "parked" in a hole with another boat less than a boat length to LEEWARD and blanketed - he suddenly sailed off and left me sitting there! It really is an interesting place to race!<img src=icon_smile_cool.gif border=0 align=middle> Derek
You are correct in considering that unequal weight distribution is a possible cause of the boat sailing better on one tack than the other.
As Arlyn points out, the same result could be caused by not erecting the mast symetrically. The mast has to be (1) in column, when the boat is at rest, as well as when it is under load, (2) the tension on the stays must be equal from one side to the other, and (3) the mast must not lean more to one side than the other. You have verified the first and second adjustments, but you should also check the third adjustment.
The best way to do that is to use the jib halliard to measure the distance from the masthead to the chainplate connection on each side of the boat.
I suggest that you make your mast adjustments first, and then, on a very windless day, adjust your weight distribution.
Also, the genoa cars need to be in the same position on both sides of the boat.
Steve M, I will take those steps as soon as I get back...My mast could be leaning to port or starboard, by sight it is straight up. The genoa cars are equal. I will use the jib halyard and see what the result is, thank You!, Steve
Duane, the motor is mounted on the Starboard side, Which brings the question...how can you tell if all the stuff you have stored or added to the boat is balanced? If the water is calm in the slip, can I set a level on the deck and then determine this then try and arrange the stuff to provide balenced ballast? Steve Steakley
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> If the water is calm in the slip, can I set a level on the deck and then determine this then try and arrange the stuff to provide balenced ballast? Steve Steakley
Better than setting it on the deck...use level vertically to check the plumb of mast which previously has been centered using a halyard from side to side. Adjust boat balance to plumb the mast.
I'm not sure how much this would effect the WKs, but my WB lists just slightly to STBD due to the heavy 4 stroke Honda 8. I try to pack all my heavy stuff on the PORT side to counter balance it.
A theory: With the outboard mounted on starboard, it offers some stiffness against heeling to port on a starboard tack. Conversely, on port tack, it will tend to drag the transom as you heel to starboard--causing additional drag as you generate more of a wake. To test this theory, watch the wake that you generate on both tacks (at equal angles to the apparent wind). The bigger the wake, the more the stern is dragging the boat. The fix: Add some heavy stuff in the port side of your aft berth to slow you down equally on starboard tacks. <img src=icon_smile_wink.gif border=0 align=middle>
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> ...how can you tell if all the stuff you have stored or added to the boat is balanced? If the water is calm in the slip, can I set a level on the deck and then determine this then try and arrange the stuff to provide balenced ballast? <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> You may have trouble finding a flat spot on the deck... Put the level from one cockpit seat to the other. If you're listing slightly to starboard, the outboard could be a factor. To counter it, put some weight well forward on the port side. That should counter the effect I hyphesized my previous post--dragging the starboard side of the transom on port tack.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Have a 250 wk with a honda 9.9 4 stroke. At rest in the marina she lists considerably to starbord. I am sure it is because of the engine.
Bill C250 wk, #614, still unnanmed <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Bill: Put a name on her--she'll level right out. <img src=icon_smile_wink.gif border=0 align=middle>
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>…how can you tell if all the stuff you have stored or added to the boat is balanced? <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
How accurate do you want to be? For practical purposes, I think Don’s suggestion will work fine. If you are prepping for a big race, you could lay about a 10 foot long piece of wood or metal with a very straight edge across the beam of the boat, perhaps in the cockpit, and use a level to determine if the boat is balanced. You would have to read the level while standing on the dock. Personally, I don’t think you need to be that accurate, even when racing, unless you’re in something like the America’s Cup, where many millions of dollars are invested in the campaign, and no stones are left unturned. When you are cruising, it usually doesn’t matter that much. It’s more important that you get all your cruising toys, food, beverages, pots and pans and sails, etc. stored out of the way, but accessible. For racing purposes, if the boat is unbalanced enough to be noticeable when you eyeball it, as Don suggests, then you can re-distribute some weight, to equalize it. If any imbalance is so slight that it is not noticeable to the naked eye, I don’t think it is significant enough to affect the boat’s performance to a meaningful extent.
You guys have given plenty of good ideas to check the balence of the boat, is it worth the trouble? Only if you are trying to beat Derek Crawford on "This Side Up", I can guarantee you he has gone every possible detail on his Cat 25! I will not sail without the beer though!, Steve Steakley
OK, HERE IS THE REPORT AFTER READING ALL THE ABOVE POST AND APPLYING TO MOON CHASER: I found that my mast was leaning about 2 1/2 inches toward the port side and I have since made the correction. I checked the weight balence and if I sit (185 lbs.) on the port side in the cockpit then the boat is level. So I guess the outboard is the difference since the stuff I have stowed below is about equal (at least in space used). Derek loaned me a level and he said he didn't think the balence of stowed stuff made that much difference....now I tend to agree since you can move the crew to achieve desired heal and use sail trim to do the rest. I still have some fine tuning to do on the rigging but your comments helped me understand what matters!, Thank you Steve Steakley
