<font face="Times New Roman"></font id="Times New Roman"><font size="3"></font id="size3"><font color="black"></font id="black">Does anybody race their C250? Any tips or suggestions for racing? I was thinking of draining the water ballast tanks to lighten the boat. Is that advisable? I’ve raced dinghies before so I’d be comfortable sailing with less ballast and controlling the boat with the mainsheet. I’d probably refill them if the wind was going to be over 10-12 knots.
I don't have a 250, but have heard that VERY BAD THINGS will happen if you sail with a less than full ballast tank.
Please don't try this.
Others will chime in with horror stories, the most recent involving kids drowning on lake Champlain when their WB MacGregor capsized while being motored with an empty ballast tank.
Rob, I raced in several community fleet events last year with my C 250 WB. The only time my ballast tank is EMPTY is removing the boat at seasons end. You should get a PHRF rating which helped me quite a bit. That was my first time racing and made some judgement errors, the boat WITH the ballast performed as well as I expected,with the double reef and IDA rudder I was comfortable in moderate winds. I tried to keep the heel at around 10 degrees or less. Your PHRF rating is based on this being a water ballast boat. Don't consider sailing that dude without full ballast tank.......
Is a race the thing that happens when you see another sailboat that is almost on a similar course and you try to see if you can keep up with it... or better ????
Yes, Paul. It should be well known that the very first sailboat race began the moment the SECOND sailboat was launched. That's true even for us non-racers!
Be aware, whether racing or not, that a partially-full ballast tank will actually <i>destabilize</i> the boat--it's worse than an empty tank because what weight is in there will go to the low side.
For racing, from all accounts, the C-250 performs best "on her feet", which suggests ballast in all conditions, to keep the sails up where they can do their job. Also, unlike a typical dinghy, if the unballasted C-250 decides to tip over, your weight is going to have relatively little to do with preventing it.
I have been racing 2nd Wind for 9 years. Removing ballast water would not be a good idea. I'm sure you will be racing PHRF and that would disqualify you. Up wind my 250 can keep up with the best. Down wind in light air is another story. a nice breeze with proper trim will kee you close.
Reducing weight will help you with acceleration, but once you hit your hull speed then all the rest is just waste. Good sails, keeping it below 10 degrees of heel and slightly pulling back on the centerboard to give it about a 60 degree angle is the way to do it. Definitely do not sail this boat without ballast, don't even consider motoring without ballast in a slight chop.
As David put it, sailing with a half full tank is even worse than an empty one.
Edited by - Steve Blackburn on 04/22/2009 21:35:24
