My stairway/ladder looks terrible. I want to refinish it but I am wondering how folks keep the refinish looking nice. Seems like minimal traffic up and down the stairs will foul the edge of each step. I had installed black gritty tape for traction and even the edges of the tape had worn through on the step edges.
I decided to compromise. I don't think you can use the steps and keep them looking great ... kinda' like you can't have your cake and eat it, too.
When I bought my boat, the PO had nailed rubber strips on the steps ... it looked AWFUL. I don't like the looks of the gritty tape either, because it seems to start peeling around the edges right after you put it on. So, I decided to try putting "grit" on the steps instead. I bought a package of deck & porch nonskid "grit" that you simply mix into the paint (Cetol in my case), and put it only on the surface of the steps.
So far I like it. The "grit" is like clear sand ... it makes the steps look a little "cloudy," but the traction is good, and it feels nice on bare feet. I keep a can of Cetol with the grit already mixed in it, and I use it to touch up the steps every now and then.
I have done the following. I sand the ladder down, and put four coats of varnish. After each coat I use a finer steel wool to smooth out. Also clean the surface with cutting fluid to get rid of dust each time. Looks great and has a glass like finish. I redo every three years.
I have two 1” strips of black anti slip tape per rung (any boat store or hardware store). Make sure where the tape is place it is roughed up to get a good adhesion.
Great winter project, just make sure you have a well-vented area to do this.
I'm in the middle of refinishing my stairs, so I don't have results to report, but I decided to use the Treadmaster SP (soft pattern) non-skid. I'm cutting it into panels large enough to cover about 75% of each step and epoxying it in place. Looks great, very low wear and is easy to clean. It's pricey though. I'll report back once it's been in service for a while.
I used the black gritty tape strips when I refinished my ladder last year. I was concerned about the grit being dislodged and then serving to mar the finish. I decided to seal the grit by carefully painting the surface of each strip with a layer of epoxy. It seems to have worked well -- they are still skid resistant, but I can see no wear on them as of yet.
Removed the varnish and stick-on rubber non-skid from ours. Simply oiled the teak after finishing with 120 Grit sandpaper. We've found that this gives sufficient footing, even when wet--as good as teak decking at any rate. All we do for maintenance now is touch up with oil, as required. Looks great, functional and low-maintenance.
