 why is bottom paint needed?
HeelinPatrick
Initially Posted - 05/22/2009 :  09:48:57  Show Profile
Ok, so I'll ask the obvious. I've read thru countless posts here, but haven't found anything on what happens if bottom paint isn't used. Is it just general growth that looks unsightly, and slows you down, or is it more of the things that grow on the boat will break down the fiberglass and do bad things??
I'll first state I'm a lake sailor. This question comes from my purchase of an idasailor rudder. I have used it for a month or so now (works great fyi), and didn't paint it. Some brownish stuff is collecting on it. I called Ida, and she said painting isn't necessary, since it's solid HDPE, can't damage it. But is that the same "isn't necessary" as the bottom of the boat, in that paint would do good in keeping things from growning on it?
Being that the boat is in water 6 months/year, and the environmentally unfriendliness of paint, stripping paint, cleaning, etc., and time needed, it would seem that a seasonal power spraying might be a decent option.
Thoughts/Feedback??
Patrick Moran
1981 SR/SK w/trailer
#2303 - "Chili Mas"
Lincoln, NE
JimB517
Response Posted - 05/22/2009 :  09:55:46  Show Profile  Visit JimB517's Homepage
growth is slowed, but not eliminated, on the toxic bottom paint.
The boat still needs monthly bottom cleaning.
If you can haul out and do a monthly pressure wash and you're on a lake, you probably don't really need it.
Response Posted - 05/22/2009 :  10:28:29  Show Profile  Visit aeckhart's Homepage
Growth is only part of the problem. Fiberglass, if left emersed in water for long periods of time, will absorb water (osmosis)and create water-filled pockets called blisters. All new hulls are warrented against the formation of blisters, generally for 10 years - at least mine was. A bottom sealer and paint will further retard the formation of this dread fiberglass disease.
If your boat spends a large part of the year on the trailer I wouldn't worry about blisters. As Jim suggests, if you have access to a ramp with an electric outlet or power wash facilities, you can clean your unpainted hull regularly so that marine growth isn't an issue either.
I power wash mine at the end of the season in September. It's fairly easy to clean as long as the growth isn't allowed to dry thoroughly.
Edited by - aeckhart on 05/22/2009 10:32:22
Response Posted - 05/22/2009 :  10:29:51  Show Profile
Bottom paint is not necessary on many lakes, and prohibited on some. I never bottom painted my previous boat on a small lake. It all depends on how much growth there is in your lake. Lake Erie grows a lot in the summer and the gulf a little in the winter, so now I bottom paint. See what others on your lake do.
Response Posted - 05/22/2009 :  10:31:25  Show Profile
Barrier coats help prevent blistering, bottom paint doesn't.
bear
Response Posted - 05/22/2009 :  10:37:25  Show Profile
1995 Catalina 250 WB bottom has never been touched except for pressure washing at end of our 5 month season here in upstate N.Y. Boat stays in the water all of the 5 months. I do try and wax it but age and old bones discourage that process at times. I also have an IDA rudder and it will develop some algae, it has never been painted either.....
Response Posted - 05/22/2009 :  12:15:34  Show Profile
It really depends on conditions at your lake. Many at our lake do not bottom paint. Of course the racers do use bottom paint (VC17) or they keep their boats out of the water until race time.
Stu Jackson C34
Response Posted - 05/22/2009 :  14:32:02  Show Profile
We sailed our C22 on Clear Lake, CA, left her in the water all summer, then trailer sailed from Alameda on SF Bay during the winters. The bottom got pretty scuzzy by Labor Day. The lake had an underwater hull cleaning service: just run your boat over it and the underwater rotating brushes cleaned the bottom! Like a car wash underwater. We never painted the bottom because of this service, but I would not wanted to have cleaned it off by hand, and there were no pressure washers at all on the lake. Your boat, your lake, your bottom, your choice.
Happy D
Response Posted - 05/23/2009 :  05:34:49  Show Profile
Al,
Don't be mislead here. Blisters only occur when water enters the hull through osmosis, as you stated, and finds unreacted polyester resin. If there is no unreacted polyester resin, there will not be any blisters. Barrier paint only helps stop the intrusion of water into boats that exhibit blisters. Not all boats will blister. Most boats that get barrier coats don’t need it.
I am thinking about only sprucing up the bottom paint on my boat and let it sluff of to see what the bottom looks like. I want to go without but the zebra mussels might be too much for it.
Response Posted - 05/23/2009 :  07:31:15  Show Profile
Plastic (aka fiberglass) cannot absorb water. Time once again for my [url="http://www.yachtworld.com/sealake/sealake_5.html"]favorite article about blisters[/url].
Edited by - John Russell on 05/23/2009 07:31:55
Response Posted - 05/23/2009 :  08:30:33  Show Profile
Good one John. Here is my favorite blisters site.
[url="http://marinesurvey.com/yacht/BuyingBlisterBoat.htm"]Should I buy a blistered boat?[/url]
Tom Potter
Response Posted - 05/23/2009 :  09:28:36  Show Profile
I spent the morning waist deep in water standing in mud fighting off jelly fish while scrubbing the bottom of the boat, had quite a bit of barnacles and growth. I made up a scrubber/scraper using a thin piece of teak as a blade on a squeegee type handle like you see in the gas stations with a scrubber on the other side, worked great. Guess my cheap WM brand bottom paint has given up. Think I'm going to switch up to Pettit Trinidad SR or Micron CSC next time. The boat now lives in a very heavy growth area year round.
Edited by - Tom Potter on 05/23/2009 09:32:39
frog0911
Response Posted - 05/23/2009 :  12:26:53  Show Profile
Tom, welcome to the club of year round bottom cleaning. A boat in the water at the end of your dock does have its drawbacks.
Edited by - frog0911 on 05/23/2009 12:27:44
Response Posted - 05/24/2009 :  08:39:51  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by frog0911</i>
<br />Tom, welcome to the club of year round bottom cleaning. A boat in the water at the end of your dock does have its drawbacks.
Oh, you guys are breaking my heart.
KD4AO
Response Posted - 05/25/2009 :  10:55:10  Show Profile
I just got my boat back from the marina with a new coat of Pettit Trinidad. It had an unknown ablative paint that was nearly gone. It now has 2 complete coat's of Trinidad, about 1.75 gallons. I have used that same paint in the past and always got good life out of it. I usually have a diver clean it at 6 weeks to 2 months. I am a firm believer that a good hard paint is a necessity on a boat that stays in salt water in the south.
Edited by - KD4AO on 05/25/2009 11:02:18
Happy D
Response Posted - 05/26/2009 :  17:08:03  Show Profile
An opposing viewpoint.
[url="http://books.google.com/books?id=QzZZcs4hGacC&pg=PA15&lpg=PA15&dq=blistering+and+osmosis&source=bl&ots=Xmm_FcrzGy&sig=EBoRFuwrAq-wKZRuRnhYXr0-pWY&hl=en&ei=W4AcSvteiMK3B6HltYEN&sa=X&oi=book_result&ct=result&resnum=2#PPA15,M1"]Osmosis and Glassfiber Yacht Construction[/url] Page 15.
[url="http://www.insightmarinesurveyors.co.uk/index.php?subpg=blistersosmosis"]Another article talking a bout plastic boats absorbing moisture.[/url]
Time once again for a little more research.
Plastic boats <b>do</b> absorb moisture.
Response Posted - 05/26/2009 :  19:32:15  Show Profile
These articles present some conflicting theories. Keep in mind that very few marine surveyors are chemical engineers--they know boats and engines, and they hear explanations of things like how moisture meters, osmosis, capillary action, and organic chemical reactions work. Their observations, experience, and (it appears) limited understanding of the underlying science produce some varying opinions of how and why things turn out as they observe them. I disagree with some things in these articles and agree with others based on a different background and some different observations. But I'm probably no more qualified to dispute them than they are to write these articles. I'm just saying don't take much of this stuff as gospel. The chemistry and physics of fiberglass laminates is strange and wondrous, and has developed mostly through trial and error. And the stuff (maybe unfortunately) lasts practically <i>forever</i>, even if a little gelcoat blisters away.
Frank Law
Response Posted - 05/26/2009 :  19:39:18  Show Profile
My boat is on a mooring in shallow water,(3' low tide) Once we found the rudder missing on our Cat 22 but luckily it floated under some bushes a 1/4 mile away..So ever since I remove the rudder and tiller every time I'm finished sailing for the day..I bolted the tiller to the rudder and remove it in one piece and store it in the cabin It really is not a big problem and keeps the rudder out of the water..
Frank Law
About Time # 3519
1983 SR,SWK
Even Chance
Response Posted - 05/26/2009 :  22:29:54  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by KD4AO</i>
<br />I just got my boat back from the marina with a new coat of Pettit Trinidad. It had an unknown ablative paint that was nearly gone.
Bob, I assume you removed the ablative before you put the Trinidad on. You can put ablative over hard paint, but not the other way around . . .
KD4AO
Response Posted - 05/27/2009 :  11:04:29  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Even Chance</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by KD4AO</i>
Yes, they removed the ablative paint then applied 2 complete coats and a 3rd around waterline.
Response Posted - 05/29/2009 :  05:20:18  Show Profile
In my humble opinion I fully disagree with the folks ad Ida regarding HDPE or any non-fiberglass plastics. I painted my Ida balanced rudder, son washed off too much of the ablative paint and I had lots of barnacles which pitted just like on fiberglass. I also own a Logic (Now Triumph) "plastic" skiff. Love the blat, but it needs bottom paint and even that company, after one year of production saying it did not need bottom paint, now say it very much does. Marine growth --from fresh or salt, clean or polluted -- will grow, in time, unless the available tools (read paint) are applied and maintained. In western Long Island Sound, a salt water area that has relatively warm (70 degree) water in summer and is not the cleanest area of the Sound, I use ablative paint and lose one full coat each short summer. On your lake, you may go a couple of years with a different type of paint, but, you will need something! And, besides, painting the bottom is an age old right of passage to see if you have any friends who really want to go sailing with you during season!
Enjoy.
Response Posted - 05/29/2009 :  06:47:41  Show Profile
That may reflect the extreme difficulty in getting <u> anything </u> to adhere to HDPE without heating to 200º and painting or gluing within 20 minutes. To the surprise of the marketing departments, either barnacles own little torches or nature can do things we can't. :)
Edited by - Dave5041 on 05/29/2009 06:48:38
Response Posted - 05/29/2009 :  09:58:55  Show Profile
<br />T...either barnacles own little torches or nature can do things we can't.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Every day, barnacles and skunks demonstrate the superiority of Nature's chemical engineering prowess over mankind's!
