 outboard motor fuse
crcox040544
Initially Posted - 06/28/2009 :  10:33:12  Show Profile
i have a evenruge yatchtwin made in the 80's.
does anyone know where the starter fuse is located.
charles cox
crcox040544
Response Posted - 06/28/2009 :  10:49:52  Show Profile
this is a 9 hp motor
Response Posted - 06/28/2009 :  15:10:29  Show Profile
I would be very surprised if it has a fuse. It may have a fuseable link, but probably not. If the starter isn't working, try shorting across the pins on the starter button to see if it's OK. The starter button usually controls a solenoid that probably has inaccessable connectors, but you can touch the hot pin on the starter with a heavy guage jumper from the battery to check the starter motor itself.
skrenz
Response Posted - 06/28/2009 :  16:09:19  Show Profile
Charles,
I think you have the exact same motor that I have, an Evinrude 9.9 Yachtwin from around 1987. If you do, lets keep track of each other because I suspect these are getting rare. BTW, do you have an owners or repair manual for your outboard?
crcox040544
Response Posted - 06/28/2009 :  19:11:05  Show Profile
No, I do not have a manual.
I have not been to concerned as it cranks on the 2nd or 3rd pull.
crcox040544@gmail.com
205-305-3508 Birmingham Al.
Response Posted - 06/28/2009 :  22:38:29  Show Profile
Forgot to add: starter buttons are a common failure point as motors age. The sealing system is usually rubber and RTV, and both can get brittle and crack with age and allow water entry and corrosion.
skrenz
Response Posted - 06/29/2009 :  16:05:12  Show Profile
Good point about the rubber boot around the start switch. Anyone know where to get a new one?
