 Bow pulpit/stanchion straightening/repair
hillerji
Initially Posted - 07/13/2009 :  07:42:59  Show Profile
Hi folks,
Can anyone shed some advice on stanchion/pulpit repair? I've got need to have the pulpit repaired if possible. The rail took a hit in a derigging incident. One base plate got driven into the deck which will have to be repaired and the rail has a major divot in it. As a result the lifeline stressed a stanchion and it needs to be straightened if possible. Once again your sage advice is much appreciated. A number of possible scenarios but no one on board (whew) and the mast recovered from over the side in one piece. Will sail eventually.
Jon
'Arabesque'
#2479
1982 SR/FK
Thames Yacht Club
New London Ct.
hillerji
Response Posted - 07/13/2009 :  07:55:41  Show Profile
All,
As I start to look at replacement parts what is the consensus on a new mast step in conjunction w/ mast step halyard plate. Is it wise to add the halyard plate or isn't it a 'need'. My experience doesn't tell me if this is a 'frill' or this is the time to do it?
Thanks again,
JH
Ed Cassidy
Response Posted - 07/13/2009 :  08:08:36  Show Profile
I had a broken bow pulpit with the front piece missing completely. I found a thicker walled but smaller outside diameter piece of stainless that fit inside the original tube perfectly and took it to a stainless steel welder. It cost me $45 to have it welded in place and polished. He said it was next to impossible to bend the original tube back into shape because of the thin wall.
hillerji
Response Posted - 07/13/2009 :  10:19:43  Show Profile
Ed,
Thanks for the insight. Thats what my main concern is if it can be rectified somehow. I'm wondering if Dave B. may have some thoughts on local 'artisans' as he's in my corner of the world.
Jon
Happy D
Response Posted - 07/14/2009 :  05:44:41  Show Profile
You might try and contact [url="http://www.catalina-capri-25s.com/forum/topic.asp?TOPIC_ID=19700"]txbigfoot[/url] for some spare parts. He parted out a C25 a little while ago.
As far as the bow pulpit is concerned, exactly where is it bent?
The reason I ask is because I have a bent pulpit and you could probably make one good one out of the two if they are bent in two different places. My pulpit is bent right at the front. It looks like the PO sat on the very front and bent it down. A welder can probably merge the two and make a good one for you. Pulpits are very hard to come by.
I can also get strait stainless tubing at a local marine store if you end up needing to go that route.
Let me know.
Happy D
Response Posted - 07/14/2009 :  05:49:34  Show Profile
I would think there are several welders in New London that do marine show quality work. Ask arorund at the marina and I'm sure a name or two will come up.
Response Posted - 07/14/2009 :  12:36:33  Show Profile  Visit DaveR's Homepage
I wouldn't call the mast step with the halyard plate going to far. It's excellent if you want to bring you vang sheet and or reefing system (or even lazy jacks) back to the cockpit. I'd say GET IT!!
NautiC25
Response Posted - 07/14/2009 :  13:03:17  Show Profile
It would be easier to find an aftermarket automotive fabrication shop to do tig welding. Tig welding is an art that not just anyone can do. They should be able to get apiece of straight pipe to match, then weld it on. Make sure to look at they're samples before you hire them. The tig weld shouldn't be more than 1/4 inch wide. To go around a 1" pipe should cost about 30 to 40 dollars each weld. Then he can polish it to look factory.
Edited by - NautiC25 on 07/14/2009 13:05:59
hillerji
Response Posted - 07/14/2009 :  13:43:01  Show Profile
Thank you all,
The plates are to be ordered momentarily and let the repairs begin!!
Response Posted - 07/15/2009 :  18:23:12  Show Profile
Up (or down) in Westbrook is the Brewer's "Pilot Point" Boat Yard. Last fall when my stern pulpit was bent, I talked to my Yard Master and he recommended the work that is done there.
Of course they are affiliates, but no matter what type of work I've had done at Brewers, they always do a great job and follow through on their promises.
You can find it on www.BYY.com and look for Westbrook.
