 gas line vacuum
Initially Posted - 07/22/2009 :  10:50:33  Show Profile
Just sharing an experience - and boy do I feel dumb! On Friday, the wind died and we had to motor back from a distance, took almost an hour and well over a 1/4 tank of fuel...the next day, the wind recovered and we were out having a fine time - sailed right up to the marina channel marker...I started the O/B to get us through the channel and to the slip - after about 5 minutes of running, the motor petered out...right as we were in the narrow channel, w/ shoals either side, I opted to sail in w/ the genny - which actually worked well, including gybing twice along the serpentine route to get to our slip, fortunately it was getting late and there was not a lot of traffic in the marina. After tying up, I checked the gas tank, and observed a significant negative air pressure when opening the cap. After pumping the bulb, the motor then started up fine...as we say at work - another learning opportunity!!!
Jerry
Ed Cassidy
Response Posted - 07/22/2009 :  12:42:21  Show Profile
Sounds a lot like you didn't open the air bleed!
Response Posted - 07/22/2009 :  13:27:24  Show Profile  Visit delliottg's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Sounds a lot like you didn't open the air bleed!<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
That was my first thought as well. I've only had that happen to me once, but it was an interesting experience. Fortunately I knew what had happened, but that didn't stop my sister from getting a bit freaked out when I handed her the tiller and told her to not hit anything while I fixed it and restarted the engine.
I think you handled it very well, and learned that you <i>can </i>get your boat back in by sailing alone, which is a fine skill to learn indeed!
Response Posted - 07/22/2009 :  13:34:25  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Ed Cassidy</i>
<br />Sounds a lot like you didn't open the air bleed!
I've never done that.
Ed Cassidy
Response Posted - 07/22/2009 :  15:43:46  Show Profile
I didn't ever do it either, I just had people tell me about it!
Response Posted - 07/22/2009 :  15:59:38  Show Profile
I can't say its happened to me, but then again I never close it. Inboard tanks are vented all the time and I never trusted a plastic tank when they swell up in the heat, so the vent stays open. If you don't have the later fuel locker I would imagine that you would want to close it so as not to get fumes down below.
Edited by - islander on 07/22/2009 16:07:25
Response Posted - 07/22/2009 :  17:04:51  Show Profile
Never happened to me either, when I was using the 6 gallon tank. Motor konked, had no idea why, but I had been having low idle problems at that time. Boy was I glad when I looked at the top of the tank and tweaked the air vent thingy. I was delighted to find it!
glen
Response Posted - 07/23/2009 :  12:20:53  Show Profile
[quote]<i>Originally posted by islander</i>
<br />I can't say its happened to me, but then again I never close it. Inboard tanks are vented all the time and I never trusted a plastic tank when they swell up in the heat, so the vent stays open. If you don't have the later fuel locker I would imagine that you would want to close it so as not to get fumes down below.
I have the older fuel locker (Don’t get me started on engineers, someone actually thought it was OK to vent gas fumes into the bilge area ! Ya Right )What I did was to add a second gas line connection to my 6 gallon tank. I installed this port on the front of the tank so it sits on top when I secure the tank in the locker. It has no fill tube attached to it inside the tank, so it acts the same as a vent. I have a Vent tube (gas line) that on one end connects to this fitting and on the orher end connects to a screened vent. The vent tube is routed to the top of the locker, then down to the tank. This loop prevents any rain or water from entering the fuel tank. I also used a different brand connection then the one for my outboard, so I can't confuse them and hook the wrong line to the the vent. (I have a 9.9 Honda, so for the vent I used an OMC connection)
Response Posted - 07/23/2009 :  13:14:23  Show Profile  Visit Prospector's Homepage
I actually haven't done this, but I have installed the line backwards, and I've had the gas line pinched under the locker while I sat on it scratching my head...
Response Posted - 07/23/2009 :  14:10:10  Show Profile  Visit DaveR's Homepage
I'm sure I've done this, but what's fresh in my mind is when I used my dinghy last I was 1/4 way to where I was going and she conked out. No auto-start, so I pulled and pulled until I ........... realized I hadn't turned the gas on ........
Response Posted - 07/23/2009 :  15:20:13  Show Profile  Visit delliottg's Homepage
Hah, you just reminded me, I've done the fuel line backwards trick once too, that bulb gets sucked down amazingly flat when you do. I looked at the bulb I don't know how many times before it dawned on my how it could get that flat and the solution became evident.
