Two sailboats. I'm boat A on a tight tack. B is on beam reach. We are in wide open water. B is an open, smaller sailboat (23ft?) headed towards me. Both are on starboard tacks. Who had the right of way?
Some guy almost t-boned me in open water, if I beared off, I would have still been on a collision course. He finally went behind me, but about 10 ft away. He looked p'd-off, I wasnt happy. Who had the right of way?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by hinmo</i> <br />David - I think it was rule 1. Both on the same tack, me being close-hauled....I had the right of way, correct? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
That's what I think too. From your discription, you were both on the same tack but on almost purpendicular courses. Just like the boats pictured in rule one of the rules web site.
Again, if I beared off, I think I would still have been in a collision course at some point. I could have tacked or jibed, but all he had to do was bear off a few degrees (which he ultimately did) and problem solved.
To quote from the rules, 'The four rules listed below give a basic overview of who has the right-of-way. If all else fails, when two boats are at risk of colliding, the boat that has the other on its starboard must keep out of the way.' Ed
Ed - in that case I was in err. But I believe Rule 1 applied, and as I stated, my bearing off a couple degrees would not have alleviated the situations....whereas Boat B only needed to alter course 5 degrees.
John, even if you were the leeward boat and had the right of way, lets not forget the first thing is that YOU have only one purpose and that is to PREVENT A COLLISION. Is it better to be right or be safe and save your boat and crew. It sounds like both parties here were unclear as to which boat was the give-way vs the stand-on boat. When in doubt, take evasive action and avoid a collision. David, thanks for that link. I have added it to my IPhone. Now when I get in a collision I can bring up the rules and show the other boat I was right and had the right of way, as we are both sinking! Steve A
Remember, racers often pass within inches. It doesn't matter if you were close hauled and he was on a reach. If he was leeward, he had right away. It doesn't matter if you were sailing upwind and he was coming downwind wing and wing.
If windward caused the leeward boat to change course even 1 degree, windward fouled leeward.
If I get the picture correctly, he was on your starboard side. If all he's learned is the "powerboat rule" (right makes right), he figures he's the stand-on vessel and you're give-way. (At night, you'd be showing him a green light and he'd be showing you red.) He probably thought you should tack--not bear away. However, if you wait too long to do so, you might be tacking as he bares off--a new problem sometimes called "Shall we dance?" Under sail (and not racing), I used to give the benefit of the doubt to the sailboat on my starboard by tacking <i>early</i> behind him. Some skippers probably figured I didn't know the rule. John's "epitaph" applies.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Bristle</i> <br /> If all he's learned is the "powerboat rule" (right makes right), he figures he's the stand-on vessel and you're give-way. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Dave, don't you mean, Might Make Right! Steve A
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by piseas</i> <br />Dave, don't you mean, Might Make Right!<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">In case anybody's wondering, I mean the basic rule that the boat on the <i>right</i> has <i>right</i> of way. That is, however, a slight mis-statement. The boat on my starboard, all other things equal, has the <i>duty</i> to hold course and speed unless I don't give way (my duty). Skippers shouldn't think of "rights" but of <i>duties</i> that are designed to avoid collisions. <i>Both</i> boats involved have those duties.
I've never understood why two boats in open water need to get close. I usually make a small adjustment adjust early to avoid that, but even 15 miles off shore on Lake Erie I've had other boats adjust to pass close.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave5041</i> <br />I've never understood why two boats in open water need to get close. I usually make a small adjustment adjust early to avoid that, but even 15 miles off shore on Lake Erie I've had other boats adjust to pass close. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> For the same reason truckers pass close- They want to see your seat covers
Folks - I should add a statement. I was tacking close hauled trying to get out of the outer harbor (SE facing) into a SE wind. He was on a reach of some sort cruising back in. When I say "open ocean", it was not really. I needed to be close hauled on the next couple tacks to get to the open bay....he had a full angle on the wind to cruise back into any portion of the harbor. I just thought it made sense (as in common sense) for him to change course a couple degrees w/o having to tack or jibe, rather than upsetting my course entirely.
Anywhoo....not a biggie....interesting interpretations
