 Boat Down!
KiteKraemer
Initially Posted - 12/14/2009 :  10:34:29  Show Profile  Visit KiteKraemer's Homepage
http://www.nwkite.com/forums/t-16256.html
I'm glad this isn't my baby; but any speculations on how this might have happened?
The marina was frozen solid recently with sub-zero temps for about 1 week.
I was thinking there might have been some water in the hull that when it froze, cracked it?
Unicorn
78•C25•SK
Hood River, Oregon
http://www.eclipsefilms.com/unicorn.jpg
Edited by - KiteKraemer on 12/14/2009 10:35:36
Rich P
Response Posted - 12/14/2009 :  12:12:47  Show Profile
Probably froze a seacock and cracked it. Once dethawed, the water started to flow.
Response Posted - 12/14/2009 :  12:13:34  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by KiteKraemer</i>
<br />...The marina was frozen solid recently with sub-zero temps for about 1 week. I was thinking there might have been some water in the hull that when it froze, cracked it?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I suspect a thru-hull with water in it froze and cracked--then thawed. (Simultaneous posts.)
Edited by - Dave Bristle on 12/14/2009 12:27:32
Elliott
Response Posted - 12/14/2009 :  13:20:12  Show Profile
What do you do to ensure you have all the water out of a through-hull? I only have the one from the sink drain on <i>Voodoo Krewe</i>. Plus, it's unlikely for Lake Pontchartrain to ever freeze, but just wondering.
Response Posted - 12/14/2009 :  14:07:02  Show Profile  Visit DaveR's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Probably froze a seacock and cracked it. Once dethawed, the water started to flow <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
OK, I'd also like to know how to ensure that the plumbing is fee of water, and as long as the water is not under pressure and has someplace to go, as in up, towards the sink or head, how could it pop a pipe?
Response Posted - 12/14/2009 :  14:31:49  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DaveR</i>
<br />...and as long as the water is not under pressure and has someplace to go, as in up, towards the sink or head, how could it pop a pipe?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">It freezes from the cold air in the hull, probably from the top down toward the seacock. Eventually, at the seacock, it's expanding in all directions with incredible force (likely over 100,000 lbs. per square inch) and no place to go. The seacock might be turned off, but when its body bursts, the game's over.
If there will be freezing temps in the hull while it's in the water, I'd pour some RV antifreeze down your drains, letting it flow out of the thru-hulls, and turn off the seacocks as it's flowing so antifreeze remains in the lines but most water has been purged.
Edited by - Dave Bristle on 12/14/2009 14:41:32
Ed Cassidy
Response Posted - 12/14/2009 :  14:31:50  Show Profile
Water expands as it reaches freezing. It doesn't expand as a balloon might; it expands like swelling wood does.
Elliott
Response Posted - 12/15/2009 :  08:37:31  Show Profile
Okay, the hippie question:
Are there environmentally friendly versions of anti-freeze? Since I'll be pouring it directly into the lake, only briefly touching the inside of the sink drain, I don't really want to intentionally poison the water, if I can help it.
It seems to me like there should be a non-chemical way to do it, also.
Just brainstorming a little bit, it should be possible to blow all the water out with air and close the through-hull while there is positive air pressure, preventing any water from coming back up the line any significant distance. Of course, you would want the air source to be low-pressure to prevent bursting the drain with air while trying to protect it from bursting with ice. I'm thinking the kind of pump you use to inflate an airbed when you go camping should work great, right off of the cigarette lighter style plug next to the sink.
The only trick will be to develop a fitting that seals between the pump and the drain. To do this, I think I'll get a standard, rubber drain plug and drill the right size hole through it for the pump hose, a little tight to ensure a good seal.
Edited by - Elliott on 12/15/2009 08:40:06
Response Posted - 12/15/2009 :  09:50:58  Show Profile
Air is actually a reasonable approach. Anything in solution would eventually diffuse out, leaving you unprotected. Keep in mind that the icebox drain "T"'s into the sink drain above the seacock, so you would want to see bubbles coming up in the water to be sure that the flap valve is patent and you're not just blowing air from the sink drain to the icebox drain.
Happy D
Response Posted - 12/15/2009 :  10:22:00  Show Profile
With a proper through hull, the ball valve can be closed and the hose disconnected. That would leave only about 1" of water in the through hull outside of the valve. You could then re-attach the drained hose.
Alcohol is the only environmentally friendly anti-freeze I know of, but I don't what kind you would use. I don't know scotch from bourbon.
If that boat had an inboard engine it could even have been the stuffing box that failed.
Response Posted - 12/15/2009 :  10:41:14  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Elliott</i>
<br />Okay, the hippie question:
Are there environmentally friendly versions of anti-freeze? Since I'll be pouring it directly into the lake, only briefly touching the inside of the sink drain, I don't really want to intentionally poison the water, if I can help it...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">The <i>propylene</i> glycol antifreezes (pink stuff for RVs and boats) are labeled "Non-toxic" and "Environmentally friendly", and are safe to use to winterize drinking water systems. You can use your own judgement about the lake. <i>Ethylene</i> glycol (engine antifreeze) is a whole different matter.
Response Posted - 12/15/2009 :  11:36:20  Show Profile
Are there environmentally friendly versions of anti-freeze? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Vodka?
Response Posted - 12/15/2009 :  18:31:08  Show Profile
If you were so inclined, you might try to put champagne corks in your through hull drains and fill them with cheap vodka or propylene glycol. Trick is, getting the corks into the thru hulls!
After the yard put my boat up on the hard, I filled my water system with the pink stuff and pumped it through the spigots, ran it down the drains (including the ice box drain) and a little bit came out of the thru hull which I caught with a bucket.
I've wrapped the boat in tarps, so I have not seen any water leaking into the boat down below, but you never know.
I stop by the yard a few times a week to make sure water's not getting in or collecting anywhere (I can see, anyway).
jbkayaker
Response Posted - 12/17/2009 :  18:22:44  Show Profile
This place might be a good source for re-float bags if your boat sinks.
http://www.subsalve.com/emergency.htm
Response Posted - 12/17/2009 :  19:00:42  Show Profile
<br />If you were so inclined, you might try to put champagne corks in your through hull drains and fill them with cheap vodka or propylene glycol.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">100 proof vodka is 50% water, and the alcohol in it evaporates much more quickly than the water... As antifreeze, it makes a good joke, and frozen plumbing.
Elliott
Response Posted - 12/29/2009 :  11:38:58  Show Profile
So, either a drinking water system antifreeze or air seem to be the best. The statements about the ice box puzzle me, though. I'm not sure where that is. Is there an ice box on the Capri, or just on the cruisers?
Unsinkable2
Response Posted - 12/29/2009 :  12:51:03  Show Profile  Visit Unsinkable2's Homepage
My boat stays in the water up til November, and we can get freezing weather as early as September. I just get a gallon or two of rv antifreeze and run it through the head and through the freshwater system. Only takes a few minutes.
It's non-toxic, and doesn't leave an aftertaste (atleast not in the freshwater system. Haven't tasted the other...)
Response Posted - 12/29/2009 :  20:29:01  Show Profile
In the spring, I pump the pink antifreeze out of the water system and put it back into the original bottle and save it for the next winter season.
Afterward, I put about 2 gallons of water into the tank, let the water swish around with the waves and then I pump it out through both faucet/pump handles. Once it's cleared out, I rinse it out again and pump that out.
Then I fill the tank with 10 gallons of water that I use for washing only. I carry bottles of drinking water in a milk crate stored under the dinette seats. I use four old Arizona Iced Tea screwcap bottles to carry drinking water and water for cooking. (I've seen the tank under the starboard settee - yuck!)
Unsinkable2
Response Posted - 12/29/2009 :  21:42:22  Show Profile  Visit Unsinkable2's Homepage
Here's one handy trick from the RV world:
If you end up with an aftertaste in your water lines (either from antifreeze, bleach, or other causes) run a tank of water through with about a half cup of baking soda in it. That'll remove any odors or tastes.
