The kit arrived and consisted of the following components: 1. Chain and Wire Rope Kit, p/n 775-2S15B11, p. 12 2. Transom bracket, p/n B-831, not shown in catalog 3. Pedestal bracket, p/n C-708, looks like #868-2 on p. 21 4. Conduit, p/n 853-250 about 2-5 ft pieces, p. 20 5. End fitting 854-250, 4 ea., p. 20 6. Galvanized wire rope clamps, 4 ea., p/n 665-187, p. 13 7. Take-up eye, 2 ea., p/n 618-312, p. 13 & p. 19. These were attached to a short rod that fits through the tiller arm and is not shown in the catalog. 8. Aluminum Pedestal Bolts, 4 ea. p/n 646-4hex with nuts Total cost $491 plus shipping ($18.50.) <img src="http://im1.shutterfly.com/procserv/47b2ce10b3127cce91c76df355800000001410" border=0>
Parts that should also have been included: 1. In-Line Conduit Greasers, p/n 918-250, 2 ea., p. 21 2. Conduit Lubricant, p/n 827-3, p. 20 3. Stainless Thimbles, p/n 643-187, p. 13, 2 ea. 4. SS pan head bolts, 3/8-16x2, 6 ea., not in catalog
The first step is to remove the pin holding the tiller arm to the rudder housing. This will save you a trip off the boat later, unless you need the exercise. <img src="http://im1.shutterfly.com/procserv/47b2ce10b3127cce91c77b99d4d10000002410" border=0> I cleaned everything out from the aft berth and then removed the aft bulkhead. The present cable is routed through a bronze housing on the starboard side and is connected to the tiller arm by a pin. All of these parts need to be disconnected. <img src="http://im1.shutterfly.com/procserv/47b2ce10b3127cce91c76df155820000002410" border=0>If you didn’t remove the pin at the rudder housing first, you will have to climb out and do it know. (I speak from experience.) If you notice in the picture there is a small pile of black rubber under the bronze fitting. This is a result of the locking nuts that hold the rubber grommet in place being loose, mine is now trash. (A lot of the bolts I checked were loose or finger tight, so check everything while you are there.)
Next you need to go on top and disassemble the pedestal. First remove the wheel, which I didn’t and had to fight it for a while. There are 4 screws holding the compass in place and are located on top of the compass, they are the larger ones. Next you need to disconnect the power to the compass light and set the compass aside. Inside there are 4 screws that attach the spacer housing and the pedestal guard housing to the pedestal. My parts were also attached with some sort of adhesive and needed a little help to come apart. <img src="http://im1.shutterfly.com/procserv/47b2ce10b3127cce91c76dff558c0000001410" border=0>I pulled the internal mechanism up and held it in place with a pair of vice grips while I disassembled the plug for the power to the compass light so it would fit through the hole in the aluminum bracket and removed the clamp holding the power wire in place. (Did you ever wonder what that bolt with the nylanut on the back of the pedestal did?) Now everything from the tiller arm up will come out.
I first attempted to fit the new bracket to the transom, its marked port and starboard so I knew what went where. The bolt pattern in the bracket was machined to match the bolt pattern in the SS flashing holding the rubber boot around the tiller arm. One big problem, the flashing only required the bolts to hold it in place, so they were hand drilled, some a little to the left, some a little to the right, some a little to the top, & some a little to the bottom. So the new bracket needed work to match up. <img src="http://im1.shutterfly.com/procserv/47b2ce10b3127cce91c76df8d4bb0000002410" border=0>This took about 2 hours to in-large the holes and grind off enough material from the top side to fit because the original slot was about 1/8 in. higher than it should have been. This is when I found out that the original bolts were too short for the new bracket. I spent 2 hours on a Sunday morning looking for 6 ea, SS 3/8-16x” pan head machine screws; I had to settle for hex head. 1 ¾” bolts would have also worked.
Now it was time to mount the pedestal bracket from the bottom, but first several things need to be done. <img src="http://im1.shutterfly.com/procserv/47b2ce10b3127cce91c76de755940000001410" border=0>The original hole was not big enough or in the right place so I used a 3 ¾” hole saw to cut a new hole which overlapped the original hole a little bit. The kit included 4 new aluminum bolts for the base of the pedestal and they were about 2” longer than needed. I chose to measure and cut before installing them, which made that job a lot easer. I had the same problem here with the bolt pattern; one was so far out that I had to make the hole a slot to fit. From the topside, after reinstalling the wire bracket, I turned the wheel shaft until the key way was on top and locked it in place with the break. I located the middle of the chain and dropped the cable and chain down the pedestal leaving equal lengths on each side. Using a couple of c-clams and squares I clamped the rudder housing perpendicular to the stern. From the bottom, I greased and inserted each cable into its conduit, which had been attached to the pedestal bracket. The last step was to bolt the pedestal bracket in place.
Now comes the hardest part of the job because you have to crawl all the way to the back and work in very small space. The take-up eye assembly is attached to the rudder arm. This has several holes in it, I reused the one at the end to keep the same ratio as before. If you use one of the closer holes, you will not have to turn the wheel as far for lock to lock but it will require more effort. The conduits can now be attached to the bracket. Be sure not to cross the cables in the pedestal or the conduits while routing them. The holes for the conduits in the bracket are offset to rout the starboard cable to the bottom of the rudder arm and the port side to the top of the arm. Edson’s catalog shows the cable going through the take up eye without a thimble but I didn’t like the sharp angle and stress this would cause so I added a thimble here, about $1.50 at West Marine. Run the cables through the eyes and clamp them, get the clamps as close to the eyes as you can or they may limit the travel length of the rudder arm. Adjust the cable tension with the take up eyes. <img src="http://im1.shutterfly.com/procserv/47b2ce10b3127cce91c76de555960000001410" border=0>
Doug, I did this project last month, but I really want to congratulate you on the excellant narration and pics. That should make this project so much easier for the next guys. Did you do it alone, and how long did the project take. We did it with two guys and it took about 5 1/2 hours start to finish. One of us worked above, and one of us worked below. I thought that it went fairly quickly & smooth. I also agree that Edson was terribly delinquent in not providing the grease cups and lube. What did you use for grease, I ended up using a Sta-Lube moly grease, which under the circumstances should have been fine....I now learn nothing is recommended except Teflon synthetic grease....Oh well, It all looks good !
<font color=blue>Well I don't know why the pictures are so small ...</font id=blue> - Doug
Doug,
For MONTHS now I have been trying to figure out why some photos are really small ... I finally figured it out!
When you are getting the URL address from Shutterfly, first click on the photo you want to post ... that blows it up ... THEN copy the URL address and use that URL address from the full-size photo for posting on the Forum.
What's happening is you are posting the URL address of the thumbnail photo in your Shutterfly album ... not the actual large photo.
Here is a link to the Test section where I just proved it to myself:
<font color=blue>... and I can't post the entire message at one time</font id=blue>
Doug,
There is a maximum size to each post, but I don't know what it is ... Mark Maxwell could probably tell us.
Also, you can go back and edit your previous postings if you'd like to post the larger photos ... just follow the above guidelines to get the new URL addresses and substitute them for the ones of the thumbnails.
Thanks for taking the time to explain pull/pull installation ... 'nice job!
<font color=blue>I will try to edit and change the picture size if someone will tell me how to do it.</font id=blue> - Doug
OK ... I'll give it a shot.
You (and only you) can edit your posted message. There is an icon at the top of your message that looks like a piece of paper with a pencil on it. Click on that icon and your message will open up so you can edit it.
When you composed your message, you inserted the photos by clicking on the "insert image" icon ... it puts brackets into your message that look something like this:
Delete that URL address and substitute the address of the larger photo between the image brackets. BTW, the URL address for the larger photo will be almost identical to the URL address for the thumbnail ... the only difference will likely be the last two or three digits. It might look something like this:
I hope that makes sense. It's MUCH harder to explain than to do. You are SO close ... you just need to use the URL address of the larger photo instead of the URL for the photo thumbnail.
Let me know if that helps, or if I thoroughly confused you ... good luck!
<font color=blue>Maybe we can get this into Tech Tips?</font id=blue> - Cathy
Good idea, Cathy ... I just sent all the photo-posting instructions to Mark Melchior to post in the Tech Tips section. I think most of us like seeing photos, and a good photo can certainly help when it comes to understanding some of the maintenance and improvement ideas that we all come up with.
Thanks for the idea ... it will save me lots of emails!
Thanks Doug for a great description and show of this modification.
What is the cable size? Did they recomend a turn radius out of the pedestal base?
The reason that the bolts were too short in the boot flange was that your boat missed a previous Edson upgrade. It was provided by Edson and included longer bolts and an aluminum stop plate that restricted rudder lock to lock travel. It of course would also have been discarded in the upgrade you did....which would have left the bolts long enough.
I am still contemplating an open wire mod... It appears that it would entail fabricating a shaft with turning blocks to install at the pedestal base, and two turning blocks at the transom. Edson catalog offers the base turning blocks but there minimum size offered is 4 inches and these would protrude significantly into the berth. With reccomendations of a 16/1 ratio of wire to diameter, a 1/8 wire would require two inch sheaves and 3/16 wire three inch sheaves. Two inch sheaves could likely be done in a way where part of the sheave is within the pedestal hole and therefore not protrude into the berth any more than the bend in the cable system.
A big issue for me....is that I would like to change the wheel to rudder ratio having complained about it my first sail....The above mentioned Edson upgrade supplied a longer actuator arm to help this and I am installed in most forward hole... but still feel its not enough.
An open wire system would provide easy methods of gaining on the ratio by either lengthening the arm even more...or a double purchase from the corner blocks to the actuator arm.
