 Cleaning Water Storage Tank/Winterizing
kirkh
Initially Posted - 11/02/2002 :  22:34:22  Show Profile
My 2000 C250WK has the 12 gallon water storage tank under the v-berth. I was going to clean it out but I could find no opening that permitted this. I know that some tanks have a hole specifically made for doing this but I didn't see one on the top, or sides. I couldn't see the aft side of the tank since it is against the bulk-head.
Can anyone give me any tips on what is the best way to clean the tank?
Also, West Marine said that one way to winterize is to empty the tank as best you can and then pour in some of their non-toxic antifreeze and run through the lines. Is this the best method?
Kirk
C250WK #490
Ray Seitz
Response Posted - 11/03/2002 :  09:53:59  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Also, West Marine said that one way to winterize is to empty the tank as best you can and then pour in some of their non-toxic antifreeze and run through the lines. Is this the best method?
Kirk that is how I winterized my tank. I used 2 gallons but I think it could have been done with one, if you got most of the water out first. The advantage to using less would be easier to rinse out in the spring. The disadvantage of course would be frozen lines if the diluted solution would not provide low enough freezing temps.
I see you have a wing keel, and I think I rember this discussion comming up maybe last spring. In that discussion I thought some of the wing keelers had access to thruogh the top of the tank. My wb 250 has almost no room between the top of the tank and the settee so I do not have access to clean my tank.
Ray Seitz C 250WB #628 Sea Major
