 Capri 25 Specific Forum
 Wobbly Spreaders
Pirate Princess
Initially Posted - 03/16/2010 :  19:59:12  Show Profile
Toward the end of last season I noticed my spreaders were quite wobbly and drooped a bit. I plan to drop my mast here soon (if the snowstorms ever quit) and look at them. I remember reading somewhere that the problem could be where they attach to the mast and it is my understanding that there is a nylon spacer that fits into the collar and it "embraces" the spreader. Has anyone replaced or worked on their spreaders with the same issue?
Karen Hawkins
Kansas City "Wheat Coast"
Ericson33
Response Posted - 03/17/2010 :  22:25:59  Show Profile  Visit Ericson33's Homepage
Karen,
I wrapped mine with leather, taped them and jammed then back into the brackets. the leather stiffened them up, no dropping, cheap fix, and adjustable. I did the repair in a chair in under 30 min. I also purchaced new hardware to replace the cotter pin, the hardware was stainless, with washers on top, between, and on the bottom, with a locknut, then a round nut, then taped.
Just an idea.
joearcht
Response Posted - 03/18/2010 :  15:01:12  Show Profile
Karen, My boat had a damaged spreader when I bought it. It was cracked a fatigued at the mast in addition to both of them being "droopy". The drawings on this website indicated two different types of brackets for attachment of the spreader. I don't know what type Chris has, but my boat has the "blade" type indicated on drawing A-2 revised 5-15-81.
I purchased new spreaders at Rig Rite, Inc. K-SP22 for $69.00 per side. I'm not sure if Rig Rite has a diagram of the cross section, but when I got mine the internal extrusions in the spreader matched up perfectly with the blade on the mast fitting. They slid right on and I cotter pinned and taped them in place for a very rigid connection. My suggestion is to see what type mast fitting you have before deciding how to proceed. I think Chris has an early boat and mine is a later boat.
