Hi All- I know this has been discussed before but looking for some specifics. I dropped my mast last fall and let it go down too far. This caused a couple of the mast step bolts to pull out about 3/4 inch. I need to repair this as well as add the halyard plate that I purchased.
- Do i need to epoxy the holes and re-drill pilot holes in the deck/compression post?
- I have a new tube of 5200, is that recommended for the mast step since I am not planning on removing it?
- Would i put any sealant in between the mast step and the plate itself? Or just between the plate and the deck?
Many thanks
-Chris OB Cool Yer Heels 1980 C-25 SR/FK L-Dinette Sag Harbor, NY
1. Yes, over-drill and epoxy then drill appropriate sized holes. Mine are thru-bolted with cap nuts. 2. Use polysulfide, there are few <u>proper</u> uses of 5200 on boats. You want to bed it, not glue it. Support the step so that there is a 1/16" bead until it cures, about 4 - 5 days, then finish tightening it. I usually countersink the screw holes so there is a wedge shaped ring of bedding to compress for a better seal. 3. It is really only necessary between the plate and deck, but it isn't a problem putting it between the plate and step if it makes you feel better.
