I am going to have my swing keel for my C25 sand blasted so i can restore the pivot pin bushing and clean it up. The sandblaster suggested powder-coating the keel after blasting. I expressed concern, and he told me he would use a zinc chromate primer and then build up the powder coat. I'm a bit leary, but he said he has done it many times before. It would be nice to not have to get my hands dirty with epoxy and faring, but it sounds like a short cut. Any comments or advice?
I have been totally unimpressed with powdercoat exposed to weather. It is cheaper to apply than pain and, in my experience, less durable. Now that I've established my bias, I will say that I don't believe that it belongs on a keel. A marine epoxy based barrier coat is long lasting and easy to touch up. Stay with the traditional approach in this instance and you'll spend less money and time in the long run. There is a polyester/epoxy powder coat system, but I doubt that that is what he is offering.
Yeah, I'm not sure how long powder coating has been around - but I'm not convinced it's the end all of protecting metal . . . especially for underwater applications.
You will always have some maintenance with a cast iron keel. Naturally, the better the seal the less the maintenance. 5 coats of Interlux 2000E is a good step towards that.
Remember metal begins to oxidize <i>the moment</i> you expose it to air!
Ditto on using Interprotect 2000E two part epoxy paint on your keel. It is designed for underwater use. That is what I am using on my new, balanced rudder. You can get on-line and goolgle it and read up on proper use an applications.
That was my gut feeling. Thank you for the response, I think i'll take the traditional approach which can be touched up easily in the future. Happy sails! G
