I am planning to clean up the sides of my boat above the waterline using 3M Fiberglass Restorer and some Collinite that Steve Madsen told us about. Some of the surface is flaking off ... it looks like a PO painted over the gelcoat.
Do you think it is paint that was poorly applied? Can I get this stuff OFF the gelcoat and just polish the gelcoat? Are you there Steve/OJ? Help! Should I use #7 polishing compound? (Where do you get that stuff anyway?)
Gee Buzz, too bad we live so far apart. If you've got flaking, I don't really know what else it could be other than paint. If you want to take the paint off (and it sounds like you do) I'd find a paint remover that's safe for gel coat and a pliable plastic scraper. Then I would sand with 800 to 1000 grit wet/dry sandpaper, followed No.7 Rubbing Compound, then No. White Polishing Compound. If not, it couldn't hurt to just go over - what appears to be paint - with the polishing compound - I purchased it at WalMart. BTW, the only reason I use the No. 7 brand products is because they work so well with a commercial grade (11 amps) polisher (1,750 rpms.) I would recommend that you buy or rent a polisher to restore the hull finish if you do decide to remove all the paint - it will make a big difference in the results. Lastly, IMHO, elbow grease is the best way to eliminate chalking -followed by Collinite Liquid Wax.
I'm glad you concur that the flaking is probably paint ... I didn't think gelcoat would flake, so it made sense that a PO put paint on it. BTW, the guy must have loved painting stuff ... he even put black lacquer over the outside teak ... 'thought I'd never get it off.
Anyway, I think I'm going to try a little sanding first. If that doesn't start to take it off, I'll go with polishing compound and see what that does. I did put some 3M Fiberglass Restorer on the starboard side a few months ago, and I was really disappointed with the results ... I guess all I was doing was trying to polish a coat of paint.
I have a buffer, but it's nothing like your commercial polisher ... that thing sounds like a beast! If I can't make any progress with what I've got, I'll have to rent a polisher similar to yours.
Buzz... Sanding could do as much damage to the gelcoat as to the paint on top of it. OJ's recommendation for a remover is a good one. It should remove most of the paint without doing any significant damage to the gelcoat. Just get the remover at a marine place--not a hardware store--to insure that it's safe on fiberglass gelcoat.
BTW, you were probably disappointed with 3M FG Restorer because you weren't restoring fiberglass gelcoat--you were restoring paint. They're very different.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> I have a buffer, but it's nothing like your commercial polisher ... that thing sounds like a beast! <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
If it turns out that your hull was indeed painted - this is a perfect example of why I always advise against painting gel coat <img src=icon_smile_dead.gif border=0 align=middle> .
Buzz, if you do rent a polisher, make sure it's a polisher (~1,750 prm) and not a grinder that you can attach a polishing pad to - else you might burn the gel coat. I returned three different polishers before settling on the Milwaukee. I can polish one side of the hull in 30 minutes. MORE POWER <img src=icon_smile_tongue.gif border=0 align=middle> !
Sometimes I'm reluctant to share some methods/techniques because they are ususally well above and beyond what the average person is willing to do. But, as I've said in prior posts, it's always as good as new or better when I've finished working on it <img src=icon_smile_approve.gif border=0 align=middle> . Hear the patting on my back <img src=icon_smile_wink.gif border=0 align=middle> ?
<font color=blue>Sometimes I'm reluctant to share some methods/techniques because they are ususally well above and beyond what the average person is willing to do. But, as I've said in prior posts, it's always as good as new or better when I've finished working on it <img src=icon_smile_approve.gif border=0 align=middle> . Hear the patting on my back <img src=icon_smile_wink.gif border=0 align=middle> ?
Your anal retentive forum member.
Steve Madsen #2428 OJ (Ode to Joy)</font id=blue>
Well Steve, no one can argue with your results ... what a great looking boat!
Related question. I've got some scratch marks on the hull. No, not from my many escapades, but a broken dock line during a storm and the hull met the dock box several times over.
What's the consensus on getting these out? The 3m fiberglass restorer or the #7 rubbing compound? I don't yet have an electric polisher, but could invest in one if its the only way to go. Also, the boat is in the water.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> I've got some scratch marks on the hull.... What's the consensus on getting these out? The 3m fiberglass restorer or the #7 rubbing compound? ...Also, the boat is in the water. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Phredde... Of course, that depends on what you mean by "scratches." The 3M won't do much except make them stand out more on the shiny surface--not abrasive enough. A light rubbing compound could help, but if the scratches are very deep, you might take off too much gelcoat around them before they're gone. Consider doing some "touch-up" with a gelcoat repair kit, followed by some very light sanding to flatten it, then compounding.
As for being in the water, a doggie leash around one ankle and tied to the mast... <img src=icon_smile_cool.gif border=0 align=middle>
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> I've got some scratch marks on the hull. <font color=blue><font size=2>I think all of us have some scratches - if you didn't scratch through the gel coat into the fibreglass, the most practical thing to do is camouflage them as best you can.</font id=blue></font id=size2>
What's the consensus on getting these out? The 3m fiberglass restorer or the #7 rubbing compound? <font color=blue><font size=2>Dave's recommendation about filling/sanding the deeper scratches with a patch kit is right on. I've never used the 3M product but I'd be willing to bet that it's not as agressive as rubbing compound - probably more like polishing compound. I'd use the rubbing compound first then step down to the polishing compound, then wax.</font id=blue></font id=size2>
I don't yet have an electric polisher, but could invest in one if its the only way to go. <font color=blue><font size=2>An electric polisher isn't an absolute necessity - but the average person is bound to run out of ambition and steam by the time they get half way down one side of the hull. A commercial polisher will give you the most consistent results in the shortest amount of time because it doesn't get tired.</font id=blue></font id=size2>
Also, the boat is in the water. <font color=blue><font size=2>That will be a losing battle. You need to apply a fair amount of pressure when you're rubbing the hull with the above products. The boat and/or your dink is going to keep moving away.</font id=blue></font id=size2>
What do you think? <font color=blue><font size=2>I think when you're done rubbing the areas that have scratches, the rest of the hull won't look so good and you'll want to polish the rest - having created more work than you anticipated <img src=icon_smile_wink.gif border=0 align=middle>
