 Dinghy Outboard Engine Lifting straps
Initially Posted - 06/03/2010 :  04:12:23  Show Profile  Visit britinusa's Homepage
As we near our Cruise in two weeks, final prep of the new Dinghy 2.5hp outboard handing system is in hand.
My final solution is to mount an outboard bracket on the Mast raising pole and use a strap to attach to the outboard motor so that we can lift it securely to it's "off the dink position".
So was looking around for a strap to make lifting the outboard easier (why don't they make them built in on the small outboards????). We found a couple in the $40 range.
Went to PetSmart, bought a Nylon 'Petmate' 'Signature' dog harness, $17. Fits like a charm!
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Response Posted - 06/03/2010 :  06:35:14  Show Profile
Paul,
Is this the harness you bought? Do you leave it on the outboard when it is running?
Petsmart "Aspen Pet Signature" dog harness
Response Posted - 06/03/2010 :  14:11:21  Show Profile  Visit britinusa's Homepage
Yep! Looks the same item, but Black, the tag reads
Signature
By
Petmate
Adjustable Nylon Harness
Large/Gros/Grande
1" x 28-36"
Response Posted - 06/03/2010 :  14:25:47  Show Profile
Paul - it's difficult to tell from the photo...is it 'tough enough' for your application?
SEAN
Response Posted - 06/03/2010 :  14:48:29  Show Profile
I was thinking a D ring attached to cover with a backing plate ..
we have a 3.3 2 stroke .
then use a snap shackel to grab it ..
Response Posted - 06/03/2010 :  16:15:56  Show Profile
sometimes you can find the outboard harnesses on ebay in the $15-$20 range.
Response Posted - 06/03/2010 :  17:05:01  Show Profile  Visit britinusa's Homepage
It's definitely strong enough! And fits like a glove. I was really suprised at how well and how easy it is to attach.
It's adjusted so that there is virtually no slack, and if I lift up on the D-Ring, it hangs almost vertical.
I'll finish the 'Crane' this weekend and post pics.
ps. we're keeping an eye on the slick as that could impact our trip.
Response Posted - 06/03/2010 :  20:59:06  Show Profile
glad to hear the harness lives up to your expectations..let's all hope/pray/wish the slick does not...
Edited by - jerlim on 06/03/2010 20:59:45
