 Mold deep in the grain of my tiller?
Initially Posted - 06/09/2010 :  05:07:58  Show Profile
Sanded the tiller down to bare wood, eliminating all of the little nicks and dings . . . but there were two small areas that looked like shadows that I couldn't sand out. Applied the first coat of polyurethane and those shadows turned black - ack!
Have taken the tiller back to bare wood again in hopes of finding something to remove these old water marks or mold.
Has anyone here faced/conquered this issue?
Ed Cassidy
Response Posted - 06/09/2010 :  06:21:39  Show Profile
Household bleach has worked wonders for me if there is nothing sealing the wood. I usually mix one part water with one part bleach and add a few drops of detergent. Put it on with a cloth and then rinse.
Ed
glen
Response Posted - 06/09/2010 :  06:44:59  Show Profile
There is also a bleach designed for wood. Very Strong. This product would be an out door rubber glove solution. Try Ed’s approach first, if that doesn’t work this could be another alternative
Response Posted - 06/09/2010 :  07:49:37  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Ed Cassidy</i>
<br />. . . I usually mix one part water with one part bleach and add a few drops of detergent. Put it on with a cloth and then rinse . . .
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Thanks for clarifying that Ed - I would have poured (drenched) it on straight from the bottle and walked away for an hour or more. Perhaps this explains why I (other than folding) am banned from laundry duty at our house?
Edited by - OJ on 06/09/2010 07:52:33
Response Posted - 06/09/2010 :  08:31:40  Show Profile  Visit delliottg's Homepage
Oxalic acid is what you're looking for. You can buy it in crystal form at your local paint store, like Benjamin Moore and mix it yourself easily. Or you can get premixed for way more money from places like Rockler or Woodcraft.
Are you sure it's not dry rot? That's what happened to mine, and it snapped off in my hand. There were no external symptoms, and like you, I'd just refinished it. I'd try spiking the wood in a few places with an icepick to see if it's soft.
If you find rot, you can probably still save it with a good penetrating epoxy. I'd recommend CPES.
Response Posted - 06/09/2010 :  10:12:17  Show Profile
<br />Oxalic acid is what you're looking for . . . Are you sure it's not dry rot . . . ? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">You hit the nail on the head there David. I did some reading and turns out the black is actually iron from the water. Mahogany is especially susceptible to this. They even recommend rinsing off the Oxalic acid with distilled water!
As for dry rot, hmmmmm . . .
Response Posted - 06/09/2010 :  10:38:17  Show Profile  Visit delliottg's Homepage
On mine, it was the Ash that failed mechanically, the Mahogany was just fine. The Ash had all these fine little black particles all through it, and when crushed by a tool, just fell into little crumbly pieces for about 4-6" on either side of my tiller extension's connector hole. On my new plywood one that I built, all penetrations are overdrilled, filled with epoxy, and then drilled into the epoxy, so there are no holes into the wood where water can get in. I soaked the plywood in three separate coats of epoxy before three more coats of Cetol. I expect that tiller, while kind of ugly, will last a <i>very </i>long time, since it's essentially a long piece of plastic and stainless steel, with a wood core now.
Response Posted - 06/09/2010 :  10:39:54  Show Profile
I used bleach on a laminated tiller and viola--the pretty stripes were virtually gone--it bleached out darker wood! I might suggest bathroom tile cleaner, rinsed off fairly quickly with water. In most situations, it turns mildew from black to brown and lets it wash away. I think most of them use phosphoric acid for an effect similar to oxalic acid--they're just more commonly available.
Response Posted - 06/09/2010 :  11:39:06  Show Profile
<br /> . . . used bleach on a laminated tiller and viola--the pretty stripes were virtually gone--it bleached out darker wood! . . .
http://antiquerestorers.com/Articles/jeff/using_wood_bleach.htm
