 Capri 25 Specific Forum
 main sail tack connection
leebitts
Initially Posted - 06/29/2010 :  20:25:18  Show Profile  Visit leebitts's Homepage
I launched my boat last week and rigged it today. Today was our first race. I could not find the parts for connecting the tack of the main. I ended up with a concoction of parts that were it not for a good cunningham would not have worked. What are folks using for connecting the tack of the main?
Thanks in advance
LeeBitts
1981 Capri 25 Hull # 142
Sailing in NH and Maine
SailCO26
Response Posted - 06/30/2010 :  06:25:27  Show Profile  Visit SailCO26's Homepage
I thought I had replied to this last night, but I had so many things going on at once that I must not have completed the post.
Your gooseneck should look something similar to this:
http://www.catalinadirect.com/index.cfm?fuseaction=product.display& product_ID=1109& ParentCat=399
The shackle is disengaged by removing the split ring and clevis pin, put the shackle thru the tack in the main, and re-attach.
Jim
leebitts
Response Posted - 06/30/2010 :  09:41:42  Show Profile  Visit leebitts's Homepage
perfect!
Scott121
Response Posted - 07/07/2010 :  06:02:11  Show Profile
Do you guys have fixed or sliding gooseneck. The Catalina Direct link talks about the CP25 having fixed gooseneck, but I'm pretty sure mine slides.
Just wondering...
Scott
Capri 25 #403
Mission Bay, CA
leebitts
Response Posted - 07/07/2010 :  07:44:14  Show Profile  Visit leebitts's Homepage
Mine is fixed
SailCO26
Response Posted - 07/07/2010 :  07:50:34  Show Profile  Visit SailCO26's Homepage
Fixed here, too.
joearcht
Response Posted - 07/08/2010 :  05:10:26  Show Profile
Hum, mine slides up and down with the cunningham tension. It looks just like the drawing in the archives (drawing no 245-33004-9). I wonder if this is a rig change between early boats and later boats? I use a sail track stop to keep it from falling on the deck when I lower the main.
SailCO26
Response Posted - 07/08/2010 :  06:36:19  Show Profile  Visit SailCO26's Homepage
Interesting. That gooseneck assy on the far L of the drawing is the same as what I have - however it's screwed to the mast (fixed). How is yours attached?
leesorenson
Response Posted - 07/08/2010 :  21:33:40  Show Profile
Mine slides...!
lee
joearcht
Response Posted - 07/09/2010 :  05:57:03  Show Profile
Mine slides up and down in the sail track. I keep it up when the sail is down with a sail track stopper, not a perfect solution, sometimes it slips, but mostly workable. Otherwise the boom just hangs on the sail at whatever height I set the sail at. My main has a larger than normal leach and interferes with the back stay. Sometimes in light wind I drop the sail down a little to help the sail clear the backstay. I don't like the set up but that is how the boat came to me and I've not purchased a new main yet (next on my list).
