 wax toilet ring miracle product
daves78
Initially Posted - 06/30/2010 :  12:38:31  Show Profile
Placed my in hull transducer using toilet bowel ring as instructed. Worked great in the 3 places I tried it. It's a miracle.
Response Posted - 06/30/2010 :  13:47:38  Show Profile  Visit DaveR's Homepage
I kinda felt the same way when I installed mine and it worked perfect the first time
Response Posted - 06/30/2010 :  19:59:52  Show Profile  Visit OLarryR's Homepage
Great news !
Only issue with using a glob of the toilet bowl wax ring is that everytime you are in the vicinity of the transducer, you feel like you have to use the head.
NCBrew
Response Posted - 07/09/2010 :  08:22:06  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by daves78</i>
<br />Placed my in hull transducer using toilet bowel ring as instructed. Worked great in the 3 places I tried it. It's a miracle.
I installed my transducer in 3 different places using the wax ring. It works but is very much less efficient. I can see the bottom well but not much of anything else(fish or vegetation)
Response Posted - 07/09/2010 :  13:39:01  Show Profile
Try placing it just to the starboard side and behind the swing keel cable volcano. Mine works very well there and I get plenty of warning as it gets shallow. It also highlights lots of little fishes!
NCBrew
Response Posted - 07/09/2010 :  15:25:56  Show Profile
<br />Try placing it just to the starboard side and behind the swing keel cable volcano. Mine works very well there and I get plenty of warning as it gets shallow. It also highlights lots of little fishes!
Thanks I will try it.
hinmo
Response Posted - 07/09/2010 :  15:43:09  Show Profile
<br /> It also highlights lots of little fishes!
those little fishes are some software developers joke....believe me, I have one on my powerboat/fishing boat too.
Response Posted - 07/09/2010 :  16:47:21  Show Profile
So is it an electronic hoax? Has anyone caught one of those electronic fishies that that fish finder finds for you?
Edited by - JohnP on 07/09/2010 16:48:37
NCBrew
Response Posted - 07/10/2010 :  06:32:38  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by hinmo</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dmpilc</i>
Those little fishes are actual returns but the fish is generated by the internal computer. If you run over a short stump it thinks it is a fish and places the fish symbol there. Turn off "Fish ID" and you will only see actual returns. You must then learn how to interpret them. I use mine all the time on my fishing boat. I fish over a wreck and can see if there are fish around the wreck. It is also great for finding bait and determining bottom type (Hard, mushy or grass).
If you are seeing too many "Fishes" try turning down the gain.
Edited by - NCBrew on 07/10/2010 06:34:03
Response Posted - 07/10/2010 :  13:13:22  Show Profile
The finders identify fish and their size by their air bladder echos, so anything with bubbles on, in, or under it can be interpreted as a fish.
edit: I've caught a lot of those little fishies while fishing for the bigger fishies. Maybe the next generation will attach "walleye" and "sheepshead" labels. Not that it matters, 'cause I'll probably still mostly catch the perch.
Edited by - Dave5041 on 07/10/2010 13:20:05
captaindave
Response Posted - 07/17/2010 :  02:47:53  Show Profile  Visit captaindave's Homepage
Thank you for the advice on using the wax seal to mount my transducer. I mounted it to the hull under the galley sink drawer.It works great. It is out of sight and is close to the electrical panel. Thank goodness for latex gloves.I had tried to secure it earlier with clear silicon but I got crazy readings for depth of our lake here in New Hampshire. I am going to cover the puck with a piece of 3" pvc pipe to avoid ever getting into the sticky wax seal. I was surprised that I didn't have the puck covered with water for it to work. My wife and I are enjoying are new to us 1984 Catalina 25. It was given to us. Yes given to us. What a wonderful blessing.
Sail Free or Die, Captain Dave 84 Cat 25 sk
Response Posted - 07/17/2010 :  04:59:53  Show Profile
What a wonderful gift! Sounds like you found a good spot for the transducer.
Happy D
Response Posted - 07/18/2010 :  05:42:41  Show Profile
I would much rather drill a hole in my hull than have one of those sticky things on board. I really don't understand the big deal about mounting a thru-hull transducer, or anything for that matter.
Response Posted - 07/19/2010 :  08:16:55  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I would much rather drill a hole in my hull than have one of those sticky things on board. I really don't understand the big deal about mounting a thru-hull transducer, or anything for that matter.
Spoken like someone who has a trailer. It would cost me $300 to pull my boat. The $2 wax ring was a much better alternative.
Edited by - Sloop Smitten on 07/19/2010 08:17:40
