 LED light connections
glivs
Initially Posted - 07/06/2010 :  19:27:17  Show Profile
LEDs draw so little power that they can require smaller gauge wire than traditional light units. I recently picked up a great used LED anchor light (OMG). The connecting wires were too small even to use a 22 gauge butt connector. How should I best connect my mast wiring (Catalina Direct, 2009) and my new anchor light pigtails? (I tried just crimping a 22-gauge butt connector using a rachet crimper but it did not even begin to hold the wires in place.)? TIA
Response Posted - 07/06/2010 :  19:57:05  Show Profile
Here are a few suggestions:
1. Solder the 22 gauge to a short piece of 16 gauge stranded wire. Place the solder connection in a thin piece of heat shrink tubing and shrink it. Wrap it in electrical tape. Do it for both leads.
This leaves you with a 16 gauge pigtail that will easily splice into a pink/red crimp connector, and the other end can be connected to your mast wiring.
2. Take a short piece of 16 gauge stranded wire (maybe 1") and strip off about 1/4" - 3/8" of insulation on both the 16 and 22 gauge wire. Twist the wires together, then slip a piece of shrink tubing over the pair and insert them into a pink/red crimp connector.
Connect the mast wiring into the opposite end of the pink crimp connector.
Either way, you can thicken up the leads on the LED fixture.
Response Posted - 07/07/2010 :  04:22:50  Show Profile
I folded the small wire back on itself after stripping. Then I made sure the bend in the end was in the crimp. Using a good adjustable crimping tool set to close tight the crimps held the wire. Double crimp in different spots.
It sure is some small wire. I hope they save some money....
Response Posted - 07/07/2010 :  05:15:29  Show Profile
Oh.. left out the obsessive compulsive part.
Then I would wrap the connection with electrical tape to try to keep any movement off the crimp, then I would mount/cable tie the wire to the bulkhead, also to prevent movement.
Kinda like the lines into a breaker box.
My electrical friends usta say "He does good work". That means, "He's slow as hell.."
