 9.8 Nissan/Tohatsu - add to preflight checklist
Initially Posted - 07/08/2010 :  15:50:03  Show Profile
Last week, coming in from a session with newbies, I heard a "clunk" sound and, looking back, noticed the outboard at an odd angle and not responding well. Both nuts at the end of a bracket just under the motor had come loose. From now on, I will check them before starting the motor. I refer you to Fig. 17A, nut #29, in the parts manual. When I figure out how, I'll try to transfer a pic of the page. It's an 8mm nut.
DavidP
Edited by - dmpilc on 07/08/2010 20:21:21
Response Posted - 07/09/2010 :  05:04:16  Show Profile
Loctite 430?
Response Posted - 07/09/2010 :  05:51:46  Show Profile  Visit DaveR's Homepage
The outboard lock should take care of that.
Response Posted - 07/09/2010 :  07:26:15  Show Profile
And the extra line on the engine. A line tying the engine to the mount.
Response Posted - 07/09/2010 :  07:31:47  Show Profile
Dave, this has nothing to do with the outboard lock. This is the mechanism that holds the motor upright and secured to the mount bracket. There are 2 spring loaded rods (#18 in the pic below) that go from the mount around each side of the motor shaft. Behind the shaft there is a rectangular buffer plate that goes over the 2 rods and is held in place by a pair of nuts (#29) with a washer flange. It is those nuts that came loose. John at Outboardsonline wrote me that he knows of only 2-3 instances where this has happened and thinks they may not have been tightened properly at the factory.
Took a photo of the computer screen to load this:
Edited by - dmpilc on 07/09/2010 08:13:08
Response Posted - 07/09/2010 :  08:35:50  Show Profile
Regular Loctite.
The loctight 430 is superglue, although that would probably work also.
Response Posted - 07/09/2010 :  09:06:42  Show Profile
How old is the engine and do you trailer or dock the boat between uses? I have an 07 that is on the stern of a boat that is on a salt water mooring. This type of failure could be disastrous!
Response Posted - 07/09/2010 :  09:50:40  Show Profile
I purchased it at Christmas, 2007 and it went on the boat spring, 2008, so it's been on the boat just a bit over 2 years. Boat has been out of the water only once, in June 2008, for some repairs and bottom touch-up.
Response Posted - 07/09/2010 :  10:12:32  Show Profile
Yepper... I'll betchya that just went on a lot of preflight checklists..
Response Posted - 07/09/2010 :  13:34:16  Show Profile
The nuts are a bit tough to get to, but it is possible to reach them with a finger and tell if they are loose.
Response Posted - 07/09/2010 :  13:43:55  Show Profile  Visit DaveR's Homepage
Ok, I get it now. Holy Crap, that is an odd thing!
