 Oil stains in cockpit
michaelj
Initially Posted - 07/22/2010 :  03:20:36  Show Profile
While changing my engine oil the other day I managed to spill some on the cockpit seats. I mopped it up but it still left a stain. Any ideas on how to get the stain out? Thanks.
Response Posted - 07/22/2010 :  07:10:44  Show Profile  Visit aeckhart's Homepage
Mike,
I'm sure there are chemicals out there that will do the job but may be harmful to your gelcoat.
I store my boat in my yard over the winter and one of the hardest stains I've found to remove is residue from wet tree leaves. I've found that if I scrub them once then let the sun work on them, they gradually disappear with an occasional scrubbing. It takes time but it works for me. Can't say that it'll work on an oil stain but it's worth a try providing you can tolerate the stain while it's eroding in the sun.
frog0911
Response Posted - 07/22/2010 :  10:05:19  Show Profile
You might try Black Streak Remover, it works great for all sorts of marks on a boat with out damaging the glass. You can find it at Walmart or West Marine.
Stu G
Response Posted - 07/22/2010 :  11:48:20  Show Profile  Visit Stu G's Homepage
We have a tree at the marina that drops tons of yellow seeds every spring that stain the deck. We use Westleys - Bleche-Wite to remove the stains. It's a tire cleaner but it does the job. Don't panic the first time you use it. The area you work on turns yellowish but that fades away after a few minutes.
http://www.amazon.com/Westleys-Bleche-Wite-Trigger-Spray-BC555/dp/B000VDEOTY/ref=sr_1_2?ie=UTF8&s=automotive&qid=1279824242&sr=8-2
Response Posted - 07/22/2010 :  21:11:00  Show Profile
I might do it in phases. IMHO, black streak remover never did anything that I could tell.
I'd start with a regular detergent - dish soap or laundry soap, or a regular boat soap. The chemical sodium laurel sulphate is a surfactant that forms a bond between water and oil - the premise behind most soaps. Wash it and rinse it several times to gradually remove the marks. The dark stains are dirt and soot mixed with the oil, so if the oil washes away with the soap, so will the dirt (so they say).
Next step is a degreaser. You can get aerosol degreasers or bottled degreasers, but before you try it on the cockpit seat, try it in an inconspicuous place like under the hatch. You can try MEK or Goof Off, but again, it could be harsh so use it with care. Go-Jo (the creamy stuff, not the sandy stuff) is also a degreaser. I'd suggest you wear rubber or nitrile gloves. If you use a degreaser, afterward wash with soap and water.
If that doesn't work, you can try dilute bleach and soap. If you see some progress, you can try strengthening the bleach solution. This may work out pretty well.
Another "miracle" cleaner is called Spray 9. Many people swear by it. I've used it and it works well on certain kinds of stains (like leaf marks).
Last thing I can mention is Mr. Clean's Magic Eraser. This can be abrasive, so again try it in an inconspicuous place, and go slow.
Good luck and always wear latex or non-latex nitrile gloves when handling strong chemicals.
And did I mention to try the cleaners out in an inconspicuous place?
Stu Jackson C34
Response Posted - 07/24/2010 :  17:43:04  Show Profile
FSR
Fiberglass Stain Remover
It's a blue liquid gel. Oxalytic acid.
captmikem
Response Posted - 07/25/2010 :  15:38:28  Show Profile
"Greased Lighting" takes off organic as well as oil stains. If its a waxed area it will take it off as well.
Response Posted - 07/25/2010 :  19:01:10  Show Profile  Visit britinusa's Homepage
From the Greased lighting site http://www.greased-lightning.com/cleaningtips/Room.aspx?RoomId=2
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Fiberglass
Keep fiberglass items clean like new with Greased Lightning! Follow manufacturers instructions for fiberglass items. Test in inconspicuous area first. Do not use on gel coat fiberglass. Spray on or apply with sponge as needed. Do not allow drying. Rinse as quickly as possible. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
