 Compression Tube: Yay or Nay
djdurrett
Initially Posted - 07/23/2010 :  13:15:36  Show Profile
So, I recently did the essential upgrate to the spreader sockets to the Stainless ones from CD. The kit came with two compression tubes. I replaced the smaller diameter tube but found that the original design was without the 1 3/4" tube. I have been researching and asking everyone from Catalina Engineers to my neighbor's dog. The unofficial consensus is that it is nice to have in there but not necessary on the C25 with the older "beefy" mast extrusions. Has anyone here done this upgrade and NOT put in the larger compression tube? If so, any negative experiences? It is a royal pain to get in there and secured. In fact there is no mention in any directions how to secure it between the spreader sockets. At least the smaller one has a bolt through it... I am looking for opinions and discussion here. I think I know what I am going to do but just thought I would ask yall your thoughts. So let me have em!
"Belafonte"
79 C25 TR/FK #1130
Bay View Marina
Lake Ray Hubbard
Dallas, TX
mytime25
Response Posted - 07/23/2010 :  18:02:07  Show Profile
I too would like some info on this subject as I have a new SS set to put on. Just haven't done it yet due to lack of how to?
Sorry I don't have any info to help, but maybe someone will chim in?
Thanks & Good luck
Ed Cassidy
Response Posted - 07/23/2010 :  19:47:17  Show Profile
I just installed the stainless spreader sockets (no instructions) and I'm a fairly accomplished mechanic. I can't for the life of me see how the large tube can be installed. I also don't get what the need for it is. I get the fact that there can be a good bit of inward pressure on the sockets but the pressure is spread over the entire socket plate. The cast aluminum socket had to be weaker and it didn't require a compression tube, did it?
Response Posted - 07/23/2010 :  20:45:29  Show Profile
The tall rig uses a different extrusion, is it a universal kit?
Response Posted - 07/24/2010 :  13:22:22  Show Profile
I cut a V notch in a pvc pipe and taped the compression tube to it with masking tape. Be sure to go behind the wire bundle or you'll never get past the steaming light. There should be a screw in the spreader cup that keeps it kind of in place until the spresder bracket is tightened.
Response Posted - 07/25/2010 :  18:14:42  Show Profile  Visit Leon Sisson's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave5041
<br />I cut a V notch in a pvc pipe and taped the compression tube to it with masking tape. Be sure to go behind the wire bundle or you'll never get past the steaming light. There should be a screw in the spreader cup that keeps it kind of in place until the spresder bracket is tightened.</i>
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"><font size="2"><font face="Times New Roman">Yeah, what he said. I used a total of 4 compression tubes at the spreaders -- one on each of the three bolts and the large diameter thinwall one right at the spreader bar base, retained by #10 fasteners. (Actually cut from the same tube it appears.)
For those of you who haven't experienced the adventure of getting your old 3/8" bolt out, if it's stuck don't be surprised and don't get in a hurry.
Re: "<i>...the fact that there can be a good bit of inward pressure on the sockets ...</i>"
As I recall, most failed masts fold at the spreaders. So I wouldn't recommend taking shortcuts in that area.
</font id="Times New Roman"></font id="size2">
