 Owners Data - Beta is online
Initially Posted - 08/05/2010 :  05:03:48  Show Profile  Visit britinusa's Homepage
Ok folks, go for it!
If you own a Catalina 25' sailboat, then please register it.
Please only 1 registration per person (even if you have two boats!) I'll deal with that issue later.
Click on the Owners Link on the left of this page.
Rules:
<ul><li>READ THE INSTRUCTIONS!</li><li>Be Nice!</li></ul>
Thanks.
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Response Posted - 08/05/2010 :  05:26:40  Show Profile  Visit delliottg's Homepage
Paul, gave it a try on my iPhone, which is a no go. When you click on the data entry fields, the keyboard pops up as it should, then immediately goes away, so you can't type. I wouldn't worry about this if I were you, just wanted to give you a heads up. I'll give it another try later when I've got a PC handy.
PCP777
Response Posted - 08/05/2010 :  09:27:00  Show Profile
I'm in. Will we be bale to edit comments?
Response Posted - 08/05/2010 :  09:42:35  Show Profile
Paul, I suggest you capture "Year purchased" instead of "How many years have you owned..."
TCurran
Response Posted - 08/05/2010 :  09:46:04  Show Profile
Concur with year's purchase vice years owned.
SJ
Response Posted - 08/05/2010 :  10:15:42  Show Profile
Will we be able to have a search feature, so that we can find other C25er's in the area?
Response Posted - 08/05/2010 :  11:01:30  Show Profile
Just did mine. I concur, year purchased would be better. I'm concerned about the e-mail address's availability in the databse. I assume it will be protected as it has been in the past?
skrenz
Response Posted - 08/05/2010 :  13:44:09  Show Profile
In your present owners list you have this entry:
#485 - Seafood, 1978 Standard, Swing Keel
Eric Schoefernacker & Matt Mattern, Chicago IL, United States
I believe that this entry is incorrect. I bought my boat from these two owners. The boat I bought was named "Seafood" The HIN is CTYK0482M78D. I believe they miss-registered the boat on this site when they owned it giving it the hull number of 485. I really doubt that these owners have a second boat of the same year with a different hull number with the same name as the one they sold me.
Response Posted - 08/05/2010 :  14:11:22  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by SJ</i>
<br />Will we be able to have a search feature, so that we can find other C25er's in the area?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">In Windows, press Ctrl-F, type <b>NY</b>, and click the arrows to skip through the list to each entry in NY. It also might help to type a space before the state code (to omit boats on CaNYon Lake and people named ToNY). I can't tell you how to do it on a Mac...
Response Posted - 08/05/2010 :  17:59:11  Show Profile
I'm in.
Response Posted - 08/05/2010 :  19:45:10  Show Profile
I entered my data for Passage today, however did not fill in years owned, and typed my email in words ..... at AOL dot com.
Will there be a way to update info in the future?
Response Posted - 08/06/2010 :  07:49:18  Show Profile
Paul is just giving himself some leeway on his self-imposed deadline.
Harleyworker
Response Posted - 08/06/2010 :  09:54:12  Show Profile
I'm in!! And it worked thru my iPhone.
Response Posted - 08/06/2010 :  10:03:58  Show Profile  Visit britinusa's Homepage
Update:
The data will be the basis for a search of boats/owners.
The email address will not be included in the search results.
You will be able to search for all records or limit the search to model type, etc.
You'll be able to sort the records by any of the displayed fields.
The next component I have to work on is the Approval process. this is where any of the officers that have access to the membership roster of the association, can approve - member, approve - guest, decline any of the submissions (you know that we get spam data input, so this avoids the data being corrupted by spammers.)
After that will be the search feature.
Eventually I'll add the option for you to login to your 'Sailors' record and edit your boat(s) listings.
That's why I'm asking that you only register a single boat right now.
Response Posted - 08/06/2010 :  10:06:40  Show Profile  Visit delliottg's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I'm in!! And it worked thru my iPhone.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Hah! That's great! Did you fix something Paul, or was my phone just in a stupid state?
Which OS are you using on your phone? 4?
Response Posted - 08/07/2010 :  08:21:25  Show Profile  Visit piseas's Homepage
David, I have been having a lot of problems with OS4. Mine is stupid too. Let me know how I can go back to 3, PLEASE!
frog0911
Response Posted - 08/07/2010 :  10:47:47  Show Profile
Paul, if you are already in the data base, do you want us to fill out a new form for the Beta format??
Response Posted - 08/07/2010 :  17:37:40  Show Profile
Thanks for your work on this Paul. Much appreciated!
Response Posted - 08/08/2010 :  12:10:50  Show Profile  Visit britinusa's Homepage
Frog (and others)
yep, if you have not put yourself and your boat into the system after 08/04/2010, please add your info.
frog0911
Response Posted - 08/08/2010 :  18:49:46  Show Profile
WILCO
Response Posted - 08/08/2010 :  19:08:10  Show Profile  Visit Prospector's Homepage
Hey Paul,
not sure if you want to go that far, but some owners may be willing to peel lat/long info off their GPs and share with you, then we could generate a google map of where the baots are. That might give info to feed location selection for the nationals.
Just an idea. As is, we could peel off all the "city" locations, but that sounds time consiming.
Harleyworker
Response Posted - 08/09/2010 :  07:11:07  Show Profile
I'm running 2 yr old iPhone. Version 3.1 really glad I haven't updated it.
Response Posted - 08/09/2010 :  18:48:13  Show Profile  Visit britinusa's Homepage
That's a good idea Chris.
When I add the 'Edit' option, I'll implement that.
Gotta love Google widgets!
