 Bimini/Cabin Cover
michaelj
Initially Posted - 08/08/2010 :  12:26:12  Show Profile
I don't know if this is unusual or not, but I have two frames, one for the bimini and one for the cabin cover with a fabric connector in between. So basically there are three separate covers: bimini, connector, and cabin cover. I would like to get one cover that replaces all three. The dimensions I have are 77" fore to aft and 67" across. Any thought as to where I might look? Thanks.
glen
Response Posted - 08/09/2010 :  06:24:37  Show Profile
Describe what you mean by cabin cover
Response Posted - 08/09/2010 :  06:57:12  Show Profile  Visit DaveR's Homepage
Are you describing a dodger?
Response Posted - 08/09/2010 :  07:07:20  Show Profile
It sure sounds like a dodger (cabin cover) Michael. If that's the case, you really want 3 pieces, not one. Take a look around your marian, particularly larger boats and you see how it works.
mlg3733
Response Posted - 08/09/2010 :  07:15:56  Show Profile
It sounds as if you have both a dodger or bimini (Over the cabin) and a bimini top (Over the cockpit) which to me seems like an excellent combination, since you can use either/or tops. If you replace the lot with one piece, you will certainly restrict those options, besides making it harder to go forward.
Response Posted - 08/09/2010 :  07:55:15  Show Profile
Are these the kind of frames you have?
If so, then you can add windows or sunbrella.
The dodger is important for ocean-going boats that sometimes sail through rain or through big spray.
Response Posted - 08/09/2010 :  12:21:27  Show Profile
http://www.pbase.com/mainecruising/image/108957007
michaelj
Response Posted - 08/09/2010 :  13:42:30  Show Profile
OK, all these posts are clearing things up. I am pretty sure that what I called a "cabin cover" is in fact a dodger. I also appreciate better the utility of having a three section arrangement. Really the only reason I wanted to repalce it is that the center section sags pretty badly. Thanks to all who responded.
glen
Response Posted - 08/10/2010 :  06:52:16  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by michaelj</i>
<br />OK, all these posts are clearing things up. I am pretty sure that what I called a "cabin cover" is in fact a dodger. I also appreciate better the utility of having a three section arrangement. Really the only reason I wanted to repalce it is that the center section sags pretty badly. Thanks to all who responded.
Try adjusting one or both of your frames. This may tighten the center “Fly” section
