 Queen size birth
mytime25
Initially Posted - 07/24/2010 :  09:31:21  Show Profile
Hello Every one, Well I finally got around to posting these pjotos of the queen size bed in the main salon.
Pic #1 I bought some 1/2" Teak and ripped down to 5/8" then took off teak cusion retainers and cut 1/2" x 5/8" teak trim to length. Glued & screwed.
Pic #2 Bought 1/2" Baltic birch plywood and cut to size also notching for table. Coated all sides with 5 coats Pettit Vanish.
Pic #3 Bought 4" High Density foam locally and cut using cordless sawzall works really well. Then convinced my wife she could sew up a cover. I know she could do it !
Pic #4 Finally a good size bed! It works EXELLENT!!!
Over all it cost about $120.00 for material, Labor our time and well worth it.
Please see below
Paul helped me out. Thx
http://im1.shutterfly.com/media/47a0d905b3127ccefae58ec9184e00000030O00Abs27Fs1aNGYPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/
http://im1.shutterfly.com/media/47a0d905b3127ccefae46b9978b800000030O00Abs27Fs1aNGYPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/
http://im1.shutterfly.com/media/47a0d905b3127ccefae5d91a582e00000030O00Abs27Fs1aNGYPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D720/ry%3D480/
http://im1.shutterfly.com/media/47a0d905b3127ccefae5bed8997700000030O00Abs27Fs1aNGYPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/
Devin
"My Time"
'77 C-25 SR/SK #59
Beaverton,Oregon
Edited by - mytime25 on 07/24/2010 19:15:59
calden
Response Posted - 07/24/2010 :  09:47:57  Show Profile
Devin:
Could you post these as pics on the forum? I can't get into shutterfly without registering an account. I'd love to see what you did.
Carlos
calden
Response Posted - 07/24/2010 :  10:25:57  Show Profile
Devin:
Okay, I just tried signing up but still can't see your pictures. Reading the fine print on Shutterfly I learn that I should be able to see the pictures without having an account. I'm not grokking what to do to see these pictures. Any idea?
Carlos
dying to view the Queen birth
Response Posted - 07/24/2010 :  13:48:29  Show Profile  Visit britinusa's Homepage
The correct format for image links is
(img)theimageurl(/img)
Replace the braces '(' and ')' with Square Braces '[' and ']'
I edited the original post so that the URL's did not make the page half a biscayne bay width.
Response Posted - 07/24/2010 :  15:11:21  Show Profile  Visit britinusa's Homepage
Devin, do you have a pic of the cabin when the QB is stowed?
tyztoy
Response Posted - 07/24/2010 :  19:40:30  Show Profile
Fantastic! I have just been told this will now be one of my upcoming projects. Well done.
Response Posted - 07/24/2010 :  20:18:37  Show Profile
That looks great...how is it w/ the boat rocking while at anchor/mooring?
Response Posted - 07/24/2010 :  20:24:26  Show Profile
Devin,
Great set up. I like the lip you installed to hold the "bridge" piece in place. And the green cushion looks good.
I have a similar arrangement, however my bridge locks over the top of the vertical edges. My QS air mattress takes up the slack and is very comfortable.
Only thing is when the bed is in place, its impossible to get around easily.
mytime25
Response Posted - 07/24/2010 :  21:25:28  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jerlim</i>
<br />That looks great...how is it w/ the boat rocking while at anchor/mooring?
Jerry,
The rocking hasn't been to bad. Most rocking is bow to stern not much side to side
Response Posted - 07/24/2010 :  21:32:19  Show Profile
When I installed a support rail I first through bolted a piece of the new rail under the seat then through bolted the new rail through the new backing rail.
mytime25
Response Posted - 07/24/2010 :  22:55:54  Show Profile
Nicely done! I too thru bolted the support. I got the idea of this from this site. Thank you to all who contribute.
Edited by - mytime25 on 08/02/2010 19:56:09
jhinton
Response Posted - 08/08/2010 :  12:33:04  Show Profile
Has anybody done anything like this with the traditional layout versus the dinette layout?
Response Posted - 08/08/2010 :  13:45:25  Show Profile
I have a traditional interior and I just lay some 1" X 4"s across from one side to the other and then lay a queen size air mattress on top. The air mattress has an electric pump built in that you can use to inflate and deflate. Works great and set up and take down can be done in 3 or 4 minutes.
Happy D
Response Posted - 08/08/2010 :  18:36:03  Show Profile
Nice Job Devin, I really like that. I am looking forward to doing that on mine someday.
jhinton
Response Posted - 08/09/2010 :  05:46:55  Show Profile
GaryB - Does the keel trunk get in the way of the 1"x4"s? That sounds pretty simple!
Response Posted - 08/09/2010 :  17:04:30  Show Profile
I don't have a keel trunk, mine's a wing keel.
I just lay the 1 x 4's on top of a couple of 2 x 4's (I keep my cushions at home)that run fore and aft to raise the 1 x 4's above the edge of the pieces that hold the cushions in place. If your keel truck is below the top edge of the seats you should be OK.
