 Yamaha 9.9
JPS109
Initially Posted - 08/13/2010 :  11:19:55  Show Profile
My 1991 Yamaha 9.9 overheated after presumably coming in contact with a submerged plastic bag. After a while, I was able to free the flywheel and then start it the next day. It now starts OK, but with a lot of smoke. I've only run it for 20 seconds or so for fear of doing more damage. The smoke has lessened, but I don't want to push my luck. Am I looking at a blown seal, valve, piston, or 'only' a water pump?
Jim
'87 Catalina 25 #5574
Blown Away
Monmouth Beach, NJ
mytime25
Response Posted - 08/13/2010 :  14:56:47  Show Profile
Jim,
Is your motor a 2 or 4 stroke? Did you notice if the cooling water stream was flowing steady? If it isn't check pump / impeller
That's all I can come up with Good Luck
Response Posted - 08/13/2010 :  19:22:20  Show Profile  Visit Leon Sisson's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JPS109
<br />My 1991 Yamaha 9.9 overheated... After a while, I was able to free the flywheel... It now starts OK, but with a lot of smoke... Am I looking at a blown seal, valve, piston, or 'only' a water pump?</i><hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">What model is it? If it's a 4-stroke, then the excessive smoke probably means it's toast. (Well, any time overheating locks up a motor, you're probably screwed.) But motors are expensive, so don't jump to conclusions. I'd try a compression check, and see of you can get a look at the cylinder walls without removing the head. Also, listen carefully for new knocking noises while it's running at low speed.
If no tell-tale water stream, then may need at least an impeller. I seem to recall those water pumps being marginal on a good day. Without being sure it's pumping water, you might still be able to run it very briefly for troubleshooting purposes only. Don't run it above idle, or for more than about 30 seconds at a time before letting it thoroughly cool.
On the Yamaha 4-stroke 9.9, I think you can double check for water circulation by removing the thermostat, pouring some water in there to fill the passages, and leaving its housing open while very briefly running the motor. If idling the motor doesn't immediately push water back out the thermostat housing, then suspect a bad pump.
Let's hear some other opinions and troubleshooting suggestions before giving it last rites.
Edited by - Leon Sisson on 08/13/2010 19:34:30
Jmurfy
Response Posted - 08/13/2010 :  20:46:04  Show Profile
I have a 1998 Yamaha 4 stroke which I've owned for 5 years. It never had much of a stream until this year after I changed the impeller. What color is the smoke? I hate to give bad news but I'd say you have a big problem.
Ed Cassidy
Response Posted - 08/14/2010 :  11:37:54  Show Profile
The reality is that if the motor locked up, it was because metal expanded to the point that it couldn't slide on other metal (piston and cylinder, camshaft and bearing, piston rod and crankshaft) In this case, it is most likely piston to cylinder wall. The instant that happens, there is damage done. If a two stroke and if there is water flow, start it up and let it run. You won't cause any additional damage that wouldn't be corrected with boring and an oversize piston. At least you would have an idea if it were still usable for the rest of the season as it is. But if it locked up, it will most likely need to be gone through. There is a very slight chance that the piston to cylinder wall damage is so light that it would be OK to continue using it but that would be unlikely. Sorry.
JPS109
Response Posted - 08/16/2010 :  06:34:11  Show Profile
All,
Thanks for your advice. Wound up being not too serious. Compression was good, cleaned out the impeller, changed the thermostat and all seems OK.
Response Posted - 08/16/2010 :  06:43:35  Show Profile
Yeah, sounds like you just honed the cylinders a bit . . .
Thanks for sharing this information - I would have never thought a plastic bag could cause such a problem.
